Most of the lights in TT are easy to take apart as to adjusting the switch I cannot speak to that. pop the lens and look for the mounting screws and remove the light should come free of the ceiling. You will then need to remove the wire nut the mfg installed which is normally a crimp fitting and when you put it back together use a screw on wire nut. good luck
Retired Navy
2016 Flagstaff 26 FKWS
