Old 07-31-2016, 08:36 AM   #1
Install 50A at home?
Apologies if this is a dumb question, but I would rather ask a dumb question then destroy my unit. Just bought a 2013 365 SAQB yesterday. I am planning to run power to where the unit is parked, and was planning on doing the 50A. I am far from expert, but have installed breakers and outlets before. Every example I have seen, though, shows a 50A/240v. The folks at the dealership must've told me 20 times "Be sure you don't plug into 240v. It will fry your electronics". So-How do I wire a 50A circuit with 120v? Is there such thing as a single space 50A breaker?
tmsbandman is offline   Reply With Quote
Old 07-31-2016, 08:52 AM   #2
TURBS's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "22"
TURBS is online now   Reply With Quote
Old 07-31-2016, 09:15 AM   #3
Thanks. But....that's 240v. Am I missing something? The fear of 240 was put into me at the dealer. :-)
Old 07-31-2016, 09:23 AM   #4
Dakota EV's Avatar
I would advise getting a licensed electrician to complete this job for you. Depending on where you live you might need to have a permit to complete this. You will also have to have the correct type of wire. Are you going to bury the wire? If it will be buried then this takes a special type of wire. Also do you want to just bury the wire or install the wire in conduit. I installed my underground wire in conduit to protect it. That also allows me to repair the wire later if something happens to it. One of my brothers just buried the wire for his connection and now he is having problems so he is having to dig up the entire wire to fix that problem. There are several important questions that you must answer before you decide how to handle this. Please do not get in a rush. Take your time and be sure that everything is correct so that you protect your investment in your camper. I hope that everything goes well for you.
Freddie & Linda
2015 Forest River Sierra 330RLS
2003 Dodge Ram 2500 4X4 Cummins Diesel
Days camped for 2016 - 46
Days Planned for 2017 - 118
Dakota EV is offline   Reply With Quote
Old 07-31-2016, 09:32 AM   #5
This diagram details how the 2 120v legs are separated in the camper so your devices do not receive 240v;
pjnlorrie is offline   Reply With Quote
Old 07-31-2016, 10:21 AM   #6
Thanks to both. Dakota EV-I do get that (conduit vs outdoor cabling, using 6ga, etc). I've done a similar project at the same house running power to an above ground pool. My only concern was how to get 120v on a 240v plug. Looks like Forest River has taken care of it internally. No permits required, thankfully.
Old 07-31-2016, 10:39 AM   #7
fonzie's Avatar
Here are a few sites for RV electrical.....
RV Electrical Systems
RV Electric
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 07-31-2016, 10:45 AM   #8
wmtire's Avatar
Howdy, where Turbs got the information in post #2 comes from this site, which really explains further what a 120/240 volt SPLIT phase 50 amp service is and how it operates. The keyword here is Split, as in two 120 volt legs)
RV Electric
If you will click on the 50 amp tab, on the page linked above, the author explains how a 120/240 split phase service works, and how it all stays 120 volts.
I also advise clicking on the outlet testing tabs too, to familiarize yourself how/why you should be testing any outlet before plugging in (your house or campground).
This is another site that explains the 50 amp split phase service too.
Electrical Tutorial - Chapter 3 - 30 Amp versus 50 Amp
2011 Flagstaff 831 RLBSS
Hypochondria is the only illness I don't have.
Old 07-31-2016, 10:48 AM   #9
Flybob's Avatar
If you do wire this yourself, Use a meter to check the voltage at the outlet as per the diagram in Post #2 before you connect the camper.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-31-2016, 10:50 AM   #10
Awesome! Thanks all. I've got it now. I appreciate the links. So....all of the 50A outlets are technically 240, but the camper wiring splits it? Why all the warnings at the dealership?
