Old 07-20-2013, 01:20 PM   #11
Grizzlygibbs's Avatar
Thanks, it's quite a mess of wires under there but I think I have it in a cozy spot now on the "wheel well hump." Just finishing up putting everything back. Hopefully it rides ok without being screwed down.
ID:	35807   Click image for larger version
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 07-20-2013, 04:15 PM   #12
Finished the install just a few minutes after my last post but I put in "The Guardian" with Kevin Costner and got side tracked. Here are pics of where I ended up setting the EMS unit (on the wheel well) and install the remote display. I used a tapered bit to drill the hole for the remote display cable.
Also, I did not want to block any of the vents so I mounted the remote in between the two vented areas of my WFCO.
It's kind of low to the floor but its no so bad I can't properly adjust or check it. Thanks for all the comments and help. Let me know by reply or PM if I can help any of you with the install process!
ID:	35818   Click image for larger version
ID:	35819   Click image for larger version
ID:	35820   Click image for larger version
ID:	35821   Click image for larger version
ID:	35823   Click image for larger version
ID:	35825   Click image for larger version
ID:	35826   Click image for larger version
Old 07-20-2013, 05:00 PM   #13
rattleNsmoke's Avatar
Nice Job. You may want to Attach the unit securely tho with an 'L' bracket just so it can't bounce around in there. According to PI's customer service, you can drill\bolt thru the plastic case without voiding any warranty.
rattleNsmoke is offline   Reply With Quote
