Old 03-09-2015, 01:45 PM   #11
geotex1's Avatar
OP, it will work fine and you are protecting both shore and generator power with you configuration. The only thing you may need to do is bond the neutral on the generator to make the EMS happy. We can build that simple bridge when you get to it.
geotex1 is offline   Reply With Quote
Old 03-09-2015, 02:00 PM   #12
Christian_D's Avatar
Originally Posted by TURBS View Post
So what i "may" have missed and now I possibly see is you do not have a switch over. Correct?
I'm not sure what that is, TURBS......something to easily switch from shore to generator power??? If I'm guessing correctly, then no....just the plug....in the campground pedestal or in the receptacle pictured for generator.
Christian
Reno, NV
2015 Georgetown 270
Days Camped 2015: 40
Days Camped 2016: 03
Christian_D is offline   Reply With Quote
Old 03-09-2015, 02:01 PM   #13
Okay. Thank you. And I assume I will get an error code on the EMS if that is the case?
As long as I don't get mini-explosions or fires, I'll be happy.
Thanks for your help.
Christian
Reno, NV
2015 Georgetown 270
Old 03-09-2015, 02:03 PM   #14
TURBS's Avatar
So, I'm going out on a limb here...
You DEFINITELY cannot have shore power cord plugged in when you fire up gennie!
Old 03-09-2015, 02:12 PM   #15
Right
Christian
Reno, NV
2015 Georgetown 270
Old 03-09-2015, 02:13 PM   #16
TURBS's Avatar
Originally Posted by Christian_D View Post
Right
Gotcha!
Old 03-09-2015, 02:36 PM   #17
geotex1's Avatar
Provided you're not working with live shore power and a propane leak, I'd say your possibility for mini explosions or fires is low!
The EMS will just give you a code if the generator needs to have the neutral bonded, and that's a cheap and easy task you can handle too.
Old 03-10-2015, 12:58 PM   #18
Team Bleu
Can't help we had Lazy Days install it while they where prepping my new Georgetown XL
DBsRedVett is offline   Reply With Quote
Old 03-19-2015, 09:24 PM   #19
I'm not the OP but I just installed the same Progressive EMS in my Shamrock 21DK. I get the open ground fault when I plug the 30A shore power cord into my spiffy new Honda EU2000i generator. Indicator lights on the generator and power cord show that all is well.
I'm ready to cross the bridge. How does one safely bond the neutral on the generator?
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 03-19-2015, 09:55 PM   #20
TURBS's Avatar
Here.
http://www.noshockzone.org/generator...utral-bonding/
