Old 09-14-2015, 12:08 PM   #1
Newly retired and ready
Installing a 12 volt plug
At the current time my Flagstaff 5th wheel does not have a 12 volt plug inside anywhere. This fall I will be camping in Smokey Mountain National Park using the battery and need to install a plug.
I plan to run the wires back to my shut off switch but my question is how heavy of wire should I use and do I need to put a fuse in the hot line. The adapter I will be plugging in that goes to my Cpap machine has a 7.5 amp fuse in it.
Gary, Susan, and Molly(the dog)
2007 Ford F-250 V10
2010 Flagstaff 8524 RLS
Gl111349 is offline   Reply With Quote
Old 09-14-2015, 12:23 PM   #2
Left Coast
I'd use 14 gauge....look at trucks, some are awful long and with the ones that look like a light show at night don't have problems.....I, personally, wouldn't add a fuse. Machine has one.
Old 09-14-2015, 12:38 PM   #3
I would add a fuse, this is a moving vehicle and if the wire should wear through between the outlet and the battery you could get a short to ground. This could cause a fire. I would put in a 15 or 20 amp fuse.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-14-2015, 12:45 PM   #4
MilCop4523's Avatar
ditto
I added a 12V plug in for powering the cell phones when at flea markets (I'm a vendor who sells flags, ball caps etc for extra income)
put the inline 15 amp fuse in as an added form of protection taking seconds to do and saves a lifetime of regrets.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 09-14-2015, 01:22 PM   #5
Originally Posted by MilCop4523 View Post
ditto
Double ditto. All power sources should be protected. The fuse in the device will protect the device but not the power source! And the protective device (fuse, CB, or other) should be as close to the power source as possible. If the wire were to short to ground before the fuse the fuse will not blow but you still have a high current direct short to ground!
limblips is offline   Reply With Quote
Old 09-14-2015, 01:46 PM   #6
bubbles's Avatar
Remember, fuses and circuit breakers are to protect wiring. Fuses within a unit is to protect the wiring (circuit) inside the unit. A fuse at the source is certainly called for in your application. JMO
Old 09-15-2015, 11:57 AM   #7
Left Coast
Being how it's for your machine, at least use a fuse-stat ( auto- reset)
Old 09-15-2015, 01:35 PM   #8
Thanks to all for the great advise. In line fuse is installed, wires are run from battery shutoff and ground and it works. The forum comes through again.
2007 Ford F-250 V10
Old 09-18-2015, 06:25 PM   #9
I just taped into light with scotch locks.
NorSnrub is offline   Reply With Quote
Old 09-18-2015, 07:02 PM   #10
Cyber Phrenologist
Radio's Avatar
I installed a 12 volt plug in the bedroom of our Rockwood 8280SS. I ran the wiring from the lighting in the cargo hold. It was close, accessible, easy, cheap, so on.
It's under the TV shelf in the side of the wardrobe. I intended it for low wattage loads like the weather radio and a 12 volt TV.
Works well.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
12 volt
