Old 06-16-2015, 02:37 PM   #21
Stormrider151's Avatar
The sales person was correct. Especially if the switch is mounted horizontally. Water can pool at the bottom and cause a short. I sealed my switch so that water cant get into the contact bolts inside the switch. Hopefully that will do the trick.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 06-16-2015, 02:40 PM   #22
Witch Doctor's Avatar
Originally Posted by Reuben Sandwich View Post
Stansoper, I had the exact same switch in my hand ready to buy it at my local West Marine - I asked what seemed to be a very knowledgeable sales person if the switch was water proof and he said no. He said it should be installed in a somewhat protected location. A little spray here and there would be OK, but not direct rain and splash off behind a car in a rain storm. I put the switch down, did not buy it, and am now back to the drawing board. Did you get different feedback? Thanks for any advice.
Reuben Sandwich
To me water resistance and water proof are two different things. Water resistance can take rain and spray, water residence means you can put it under water. West Marine switches are water residence not water proof.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 06-16-2015, 05:49 PM   #23
stansoper's Avatar
I would think that if it started to show corrosion, it should be cleaned. It's marine grade, so it should be fine unless you park your battery box under water! :-)
stansoper is offline   Reply With Quote
battery, battery disconnect
