Hello ,
I have a Prime Time Tracer 3150 and going to install an EMS by Progressive Industries. I would like to know if anyone is familer as to where the transfer switch is located and the best/cleanest way to access this area.
My guess is that its under the pantry's bottom shelf. There appears to be a cavity in that area for the power cord to retract into. From the inside there is a 1x1 wood panel directly below the lowest shelf of the pantry that I could cut into, but I want to be 100% certain before doing so.
I shot a message out to Prime Time, but I will not likely get my answer until Monday/Tuesday, so looking to the forum for some insight before I jump in with both feet.
The install seems pretty basic, I'll make certain to disconnect the fuse box, shore and battery power before starting any of this. I just want to confirm where I gain inside access to. The TT fuse box is on the opposite side below the fridge, and completely accessible.
Here is the link to the floor plan - I don't believe I know how to properly embed the Tracer's link but here it goes:
If you can shed any light to this, I'd appreciate the help.
Thanks! Joe
