Old 09-17-2019, 09:50 PM   #1
Capt6pak's Avatar
intelligence-power 9200 not charging batteries
I have a 2018 FR3 30DS. having charging issues. my inverter is not charging the batteries. 13.6 volts coming out of inverter, all voltage in the battery compartment leading to battery control center is 13.6. battery voltage is 4.5. disconnect solenoid will not activate. all breakers and fuses appear to be on and intact. i puta meter on the battery and no additional voltage is coming to the battery to charge them. any thoughts
2018 FR3 30DS
1997 and 2018 Wrangler
Capt6pak is offline   Reply With Quote
Old 09-18-2019, 01:34 PM   #2
You might try bypassing "disconnect solenoid" temporarily and see if you then get charging voltage at the batteries.
Could be bad solenoid or depending on where the solenoid control obtains it's voltage, the battery might be too dead to activate it.
FWIW, battery voltage of only 4.5 is well beyond D-E-A-D and may not be able to be charged.
This is a good time to check battery terminals and connection to ground. Corroded connections can lead to issues like this. Lead Acid battery terminals should be removed, cleaned well (to shiny metal) and reconnected at least annually to insure good performance
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-18-2019, 07:25 PM   #3
Capt6pak's Avatar
Problem Solved !! batteries were to low to engage solenoid she is charging fine now. going to install battery on/off to stop the constant drain.
2018 FR3 30DS
batteries, charging, power
