Old 02-19-2012, 09:48 AM   #1
LKicklight's Avatar
Inverter
Our Sunnybrook Travel Trailer has an inverter off switch we can turn off when leaving the coach...we leave the AC power on with a small heater running while we are away. This coach is parked on a deeded lot in North Georgia.
Our new Crusader is basically kepted in the same condition with the AC power on running a small heater, we would like to turn off the inverter similar to the Sunnybrook, is there a breaker or switch that we can do that.
Either coach is usually left un-attended for a few weeks at a time...
LKicklight
LKicklight is offline   Reply With Quote
Old 02-19-2012, 10:27 AM   #2
TURBS's Avatar
I think what you have is a converter not an inverter .
I'm not sure why you would want to shut it off it does keep your battery charged.
Most newer converters are hard wired no way to shut it off or flip the main breaker on the converter.
Old 02-19-2012, 02:00 PM   #3
LKicklight's Avatar
Converter
You are so right, Conveter..and yes it does keep the battery charged...but what I failed to mention was, I keep a battery tender on the Sunnybrook when not in use..I like being able to disable the Converter when we are not around..
Wish the Crusader had that option..sure something could be wired it..
Thanks for the correction..
kickback
