I'm installing a 1000W PSW inverter in my trailer's front pass thru storage. No permanent mount of the inverter. I will hook it up and remove it during each boon dock trip.
What size AWG green insulated wire should be used to connect from a 1000W inverter's rear panel to the chassis? The wire run is about 4 feet.
All my instruction manual says is "In any installation, heavy duty green-insulated wire should be used for this connection." I did research this but could not find anything.
Camp4two
