Old 05-07-2013, 04:44 PM   #1
miatared's Avatar
Inverter draw when switched off?
Just curious. I have finally installed my 1000W Xantrex Inverter and it works fine.
It is connected directly to by batteries (2 x 6V), using 2GA wiring, 5ft long.
When switched off, does the inverter draw anything ? I do not want drain my batteries while in storage. I have a Disconnect Switch, but elected to wire the inverter directly to Pos+ and Neg- of the batteries.
From what I could read in the manual, it draws .3A when turned ON with no load, but it's not clear to me that the draw is 0 (nil) when powered off.
Thanks,
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-07-2013, 05:00 PM   #2
TURBS's Avatar
Should have no draw when switched off.
Unless it has an off led indicating light.
Ie green on red off.
Turbs
Old 05-07-2013, 05:55 PM   #3
miatared's Avatar
That's what I am thinking. When OFF no draw at all.
I will take a look tomorrow at my voltage after a few days.
Thanks.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
