Old 12-26-2015, 12:48 PM   #1
Inverter Install
Hello,
I would like to install an inverter and plug my shore power cord into the inverter. I know I will have to shut off the converter, so it will not charge the batteries in a continuous loop. I know this set up will power all my AC receptacles. I am wondering about the DC powered water pump, and lights? Will they still work as long as I leave the battery switch in the on position?
Leprechauner is offline   Reply With Quote
Old 12-26-2015, 01:33 PM   #2
Kenny kustom's Avatar
That's not exactly how this works.
Please research the proper way to use an inverter.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-26-2015, 02:12 PM   #3
A inverter uses the battery 12dc and turns it to 110vac.
clutchd is offline   Reply With Quote
Old 12-26-2015, 02:21 PM   #4
And your point? That's why I want to plug the shore power cord of the motorhome into it.
Old 12-26-2015, 02:30 PM   #5
So what you want to do is power the shore power cord off the batteries in your coach via an inverter?
If that a what I understand there is a easier way I'd you have an open breaker in the power center. Hook the inverter to your 12vdc batteries and run the 110vac cord to the breaker box. Hook the black to the breaker, white to the neutral buds bar and ground to the ground bus bar. This will be an aux power source. So simply leave the main off, turn on the aux breaker and turn on the inverter
Old 12-26-2015, 02:31 PM   #6
KMP44's Avatar
How many 110v circuits do you have for your outlets? In our trailer, all the outlets are on one circuit which makes for a pretty simple inverter install. If you research a subpanel setup you will see a common setup for a hard wired inverter setup.
By using that subpanel concept, but only wiring into one circuit it gets easier. You just spice into the outlet circuit after it comes out of the panel and install your inverter & transfer switch. The transfer switch passes power through to the circuit when shore power is available and automatically kicks on to supply power from the battery when shore power isn't present.
That avoids having to turn the converter off. Plus in your original concept, you are powering your fridge on battery unless you manually switch it to gas. Plus you would be powering your microwave and AC circuits. If somebody accidentally flipped the AC switch you could have real issues. You would really need to turn the AC circuit off before using your proposed "whole house" setup.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 12-26-2015, 02:31 PM   #7
fonzie's Avatar
Yes, DC water pump and lights will still works until battery (or batteries) voltage is too low to support.
Fonzie
Old 12-26-2015, 03:33 PM   #8
Left Coast
What size inverter?
Old 12-26-2015, 03:37 PM   #9
bikendan's Avatar
Does the OP's RV have the battery capacity to do what he wants?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 12-26-2015, 04:06 PM   #10
Samlex PST 1500-12, 2 group 27 deep cycle batteries. I just want to be able to watch a little TV at night and make coffee in the morning, without generator noise. I also have a 120 watt portable solar panel , with 10 amp, built in controller.inverter is hard wire able.
Thank You
inverter
