Originally Posted by Jerry3535
Just got my 5th wheel and I'm not use to the charging system when I have the camper plugged in and my battery shut off from the unit and turn the inverter on it slowly draines my batteries down and when I shut the inverter off it charges and maintains my batteries. This can't be right or is it.
It charges my batteries up to 12.4volts.
I have a WF-5100 Series 1000 Watt Inverter.
I don't know the details of your system, however you want the inverter off when you are plugged in to shore power.
When the inverter is on, it assumes you are wanting to draw from the batteries. My guess is there is a transfer switch that is ignoring the shore power (for circuits on the inverter) when the inverter is on. When the inverter is off, shore power will be routed to the circuits that are also served by the inverter. The converter will also charge the batteries.
Not knowing how your system is wired, I can't say what all is going on... but you should not have the inverter on when on shore power. Not sure how "intelligent " your system is with regard to automatically switching from shore to inverter to generator, etc.
