Old 04-07-2013, 12:20 PM   #1
Inverter Problem
I have a 2012 Coachmen Sportscoach Pathfinder with a Magnum 2012 inverter which we purchased in October 2012. We used the inverter on a trip to Florida in December and it worked just fine. However, on a recent trip to Kentucky it stopped working half way from Michigan to Kentucky.
Upon our return home, I tried to determine why the inverter was not working. This is what I have done so far:
Read the owners manual (several times)
Checked to make sure the inverter is on and operating as instructed. The inverters green LED lights blinks when going through the charging stages as indicated in the owner's manual. I also opened the AC Access Panel to look to see if any of the wires came loose. I gently pulled on the wires to make sure they were tight. They were.
I checked the ME-RC Remote control and it shows that the inverter is charging and all the factor settings are correct.
All of the appliances work just fine when connected to shore power or when the generator is running.
However, when I disconnect the shore power and switch to the inverting mode none of the appliances (residential refrigerator and tvs) work.
When fully charged the remotes screen reads Full Charge DC: 13.7V + 0A.
The indicator light on the RV show that the house batteries are at full charge.
When I extend a slide out the remote screen changes to DC:13.7V + 24A but then returns to 0A.
When I turn on the generator and ran it for about 20 minutes, then turned it off, and switched to inverting, the appliances still dont work.
Does anyone know why the inverter is not working?
Schefjeff is offline   Reply With Quote
Old 04-08-2013, 06:45 AM   #2
Herk7769's Avatar
Magnum 2012 Inverter Magnum ME-2012 2,000-watt 12VDC/120VAC off grid Inverter
I have to say this sounds like an awesome Inverter/battery charger! (except for the part where it is not working now ).
It sounds like the fuse between the battery and the Inverter/Charger has blown.
If you have the one I am thinking of, it can be reset by pushing the little button on the side of the fuse.
The indicator light on the RV just shows the voltage present in the distribution panel and NOT the voltage AT the house battery (which is most likely dead at this point).
HAM CALLSIGN - KC3FFW
