Old 03-07-2016, 06:35 PM   #1
Inverter question
There is a switch in the camper that turns the inverter on & off. When connected to shore power, which will be 95% of the time, do I turn it on? Or leave it off? Not sure which is correct. Thanks
kasedian is offline   Reply With Quote
Old 03-07-2016, 09:26 PM   #2
I usually turn mine off when connected but leave it on all the time when using the coach and on the road. When 110 volt is present from shore power or the generator, it just goes into an idle state and draws very little and just sits there. There are some who leave it on in case of power failure, but it's a personal choice. You won't hurt it and it doesn't take any significant power.
2015 335DS
ScottBrownstein is offline   Reply With Quote
inverter
