Old 10-22-2016, 07:34 PM   #21
Flybob's Avatar
Add up the wattage listed on the two fridges. On a sunny day you will need about 125% of that in solar panel wattage to run them . On cloudy days or at night, you will need another source of power. If you plan to use batteries, you will need several and twice the number of panels to charge the batteries while the first set is running during daylight. An 18W panel will provide less than 1 amp ( @12VDC) in full sun.
Originally Posted by rcrg24 View Post
The service tech manager where I bought the camper said that this solar panel would be plenty to keep the batteries charged for the refrigerators. I'm so bummed.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-22-2016, 07:37 PM   #22
Flybob's Avatar
TST Tire Monitors
2 100W solar panels
Old 10-22-2016, 09:07 PM   #23
Ok...after all the responses I am now looking into just replacing the fridge with one that will switch to propane Thanks for all yalls honest advice.
rcrg24 is offline   Reply With Quote
Old 10-23-2016, 03:09 AM   #24
I think you will find that 600 watts of solar is cheaper than a new big fridge.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 10-23-2016, 08:07 AM   #25
SeaDog's Avatar
Be honest with yourself are you really going to boondock that often to warrant a fridge change. My guess is <3% of all RVs on the road truly boondock all the time. Just something to think about.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-23-2016, 09:19 AM   #26
NMWildcat's Avatar
I understand your thinking, but fridge replacements are expensive. Solar is nice, but IMHO, also just too expensive right now to do it right. So we just use our generators to keep the batteries charged. Easy. We boondock 80% of the time running generator 4-5 hours a day. Tell that tech who gave you advice that he needs a new job
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
inverter
