Old 09-12-2015, 06:53 AM   #1
Invertor issues TV radio
I hooked up battery backward blew the 2 40 amp fuses. Replaced those everything works except for TV/radio. When I pull fuse for TV/ radio it's fine but red led next to it comes on??
Popwarner3788 is offline   Reply With Quote
Old 09-12-2015, 04:34 PM   #2
bikendan's Avatar
please post year/make/model of RV you're talking about since you don't have it listed in your sig line.
Equalizer WDH
Old 09-12-2015, 04:47 PM   #3
2010 Coachman Freedom Express LTZ
Old 09-12-2015, 04:52 PM   #4
bikendan's Avatar
as far as i know, your trailer doesn't come with an INverter, only a CONverter.
unless you or a previous owner installed one.
all RV's come with a CONverter, which converts 110v AC shore power to 12v DC power.
INverters do the reverse.
sounds like you're talking about a red led on the CONverter.
Equalizer WDH
Old 09-12-2015, 04:52 PM   #5
[QUOTE=Popwarner3788;981342]I hooked up battery backward blew the 2 40 amp fuses. Replaced those everything works except for TV/radio. When I pull fuse for TV/ radio it's fine but red led next to it comes on?? 2010 coachman freedom express LTZ
Old 09-12-2015, 05:04 PM   #6
Ok it's a converter
Old 09-12-2015, 05:04 PM   #7
TURBS's Avatar
There's another fuse behind radio.
Possibly for the tv to.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-12-2015, 05:08 PM   #8
Ok I will look radio mounted into a cupboard. Have to unscrew it and pull it out. When I pull the fuse for both its good but red led light next to fuse comes on. By book says that means "open circuit"
Old 09-13-2015, 12:49 PM   #9
rsdata's Avatar
that means another fuse in that line may be blown
TV should be 120 AC, but radio 12 VDC
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 09-13-2015, 12:50 PM   #10
TURBS's Avatar
It's possible it's a 12v tv.
My flagstaff had one.
TURBS
2011 32bhok Sabre
radio
