Old 01-26-2016, 01:07 PM   #11
Georgia Frog Rally 2018
aceinspp's Avatar
Originally Posted by Steelhorzz View Post
If the corrosion is as bad as you say, you should also remove the batteries and treat the tray and hold downs the same way as the batteries. Then remove as much of the loose paint as possible from the trays. Before reinstalling the batteries spray the tray and hold down with automotive undercoating, "rubberized", (found at most auto parts stores). It will protect those parts in the future from further damage by the battery acid.
X 2 later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 01-26-2016, 02:36 PM   #12
My brother who is a good auto mechanic used to tell me to pour some Coke on the terminals to remove corrosion. The acid in coke eats it away.. (Also good for cleaning toilet minerals/abrasion.)
mtnlvr is offline   Reply With Quote
Old 01-26-2016, 05:04 PM   #13
A number of good tips. Thanks.
hikerjohn7 is offline   Reply With Quote
Old 01-26-2016, 05:06 PM   #14
How do you hold the penny to the post?
Old 01-26-2016, 05:23 PM   #15
Boss Hoss's Avatar
I've used both coke and baking soda-I prefer the baking soda and save the coke for the
Rum !!
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 01-26-2016, 05:58 PM   #16
FF,Retired.
Batter corrosion.
For many years I've sprayed hot water from a hose on all the battery parts as well as the tray. It takes everything off.
I let it dry or blow it off with an air hose.
I then spray Fluid Film on the tray & all connections.
No more corrosion for years.
Love13 is offline   Reply With Quote
Old 01-26-2016, 09:39 PM   #17
Wingdreamer's Avatar
Originally Posted by Al Fiallos View Post
Grampa Jim is spot on. Bi-carbonate of soda (baking soda not baking powder) neutralizes acid and if it gets into your battery it will kill it. If you have maintenance free batteries you are much better off.
Corrosion across the top of a battery will also slowly drain and kill the battery because it creates a short circuit between the positive and negative terminals. I find that vaseline works if you cannot get a good di-electric grease.
Agreed!!
After a lifetime in the auto repair industry, I STILL cant believe that anyone would recommend to use baking soda to clean a battery......That is the worst stuff you can get near a lead acid battery (unless you want to kill it....)
Use it to clean connections, cables, battery box, but DO NOT get baking soda on the top of a battery! Washing it off will liquify the soda and allow it to run down into a cell, neutralizing it permanently...
Dielectric grease is excellent at protecting clean connections and posts...
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 01-26-2016, 10:01 PM   #18
Originally Posted by hikerjohn7 View Post
My Georgetown coach batteries were collecting corrosion and rusting the tie-down fasteners and steel support shelf as well as staining my concrete pad. A mechanic suggested mixing baking soda with water and sprinkling it on the batteries. I tried it and the corrosion problem went away. I have to redo the backing soda ever few months. My question is: is it bad for the batteries to coat them with a residue of baking soda?
No, it's simple chemistry. Using a "base" baking soda to neutralize an acid. Your mechanic is dead on. Mixing the base solution with the acid spill renders the resulting solution neutral chemically, thus mitigating corrosion. And I agree follow up with dielectric grease on the terminals.
Old 01-27-2016, 09:52 AM   #19
Baking soda works well as does Coke. We use a spray on battery terminal protector (CRC Battery Terminal Protector is an example). We have used this for years on our boat batteries and never get corrosion.It is red when applied and is dry once applied. This is used frequently in marine applications. Our 2500TS batteries came coated with this type of product.
It is also good to either use a wire brush terminal cleaner or medium grit sandpaper to get rid of oxidation on the battery posts and rolled into a tube to clean the inside lead cable end (or copper connectors on smaller battery applications).
PenJoe is offline   Reply With Quote
Old 01-30-2016, 10:27 AM   #20
Too Tall's Avatar
The thing that scares me about sprinkling baking soda all over the top of the battery is that you are depending on the seal of the cap to keep the rinsed fluid out of the cells. The holes are flush with the top of the battery so any leakage and you've killed or damaged a cell. But baking soda is definitely a great neutralizer but so is plain water. Dilution is the solution? Every battery I've ever seen with that red grease has no corrosion.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
battery
