Old 06-21-2016, 03:57 PM   #11
Left Coast
Also, depends on which converter you have
Sent from my XT1585 using Tapatalk
Old 06-21-2016, 04:08 PM   #12
Originally Posted by grumpy0374 View Post
Read some old posts about adding about 2 ounces of pure mineral oil to each cell to avoid water going by by.
Have two 12 volt in our 2012 Lexi, OE, going on 4 years old. Added 2 oz of mineral oil to each cell about 1 1/2 years ago, and have yet to add any water since then. Check them every two months or so, and still full, still at full charge.
Grumpy
Fascinating. I am off to Google to look into the mineral oil thing.
In the meantime my batteries are getting a bit weak so I may throw a little Viagra in each cell to get them back "up" to maximum charge.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 06-21-2016, 04:28 PM   #13
I will check tomorrow to see what type of converter I have. The RV is a 2014 Forester 2861DS, so it is a newer model. I guess the good thing is that none of the responses are explicitly saying it is a bad thing to do.
mrmilo is offline   Reply With Quote
Old 06-21-2016, 04:29 PM   #14
Left Coast
Just requires a little look once in a while
Old 06-21-2016, 04:34 PM   #15
BamaBob's Avatar
Also, consider buying a Electrical Management System (a lot of us on the Forums use the Progressive one - your choice: hard Wired or portable:
Progressive Industries RV Surge and Electrical Protection industry lea
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-21-2016, 04:36 PM   #16
Georgia Frog Rally 2018
aceinspp's Avatar
I keep mine plug in on 30amp using an adapter to use 110. I just check batteries every so often. Also leave un plugged once in a while to deplete batteries then recharge. Only time I use the 30amp is when I need to run the air while working inside. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 62
Old 06-21-2016, 04:37 PM   #17
Left Coast
What's the stay'n.....pay me now, or step up later...
Old 06-21-2016, 04:41 PM   #18
mark0224's Avatar
Mines plugged in all the time, it also has a battery disconnect. Just turn the batteries on every so often to charge them.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-21-2016, 04:42 PM   #19
Bluepill's Avatar
Here in Florida, The Lightning Strike Capital of the USA, I never leave it connected when storing.
Just remember that anything plugged in is subject to surge damage (even with a "surge protector") and is also a possible source for a fire in the event of a component failure.
2008 Itasca Meridian 37H
Old 06-21-2016, 04:42 PM   #20
Left Coast
The cats meow would be a 4stage convertor
power
