Old 07-20-2015, 12:25 PM   #11
hammer55's Avatar
you can put new ends on the cord, we use to use them all the time in industrial situations, instead of buying a who;e new cord, as long as there is no breaks in the cord, it is fine
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 07-20-2015, 12:45 PM   #12
milvet33's Avatar
I had a 30a connector melt once. Smart electric guy told me it was low voltage that caused it. Went right out and bought a new cable and a Surge Guard.
milvet33 is offline   Reply With Quote
Old 07-20-2015, 02:05 PM   #13
Hammer55 - should the OP test his cord after removing the defective end(s) prior to re-using it? I agree some $$ can be saved replacing the ends vs buying a whole new cord, but based on some of the above posts I got the feeling that was unsafe. I have no significant electrical knowledge, so simply asking so I can learn.
Brian
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 07-20-2015, 02:10 PM   #14
Probably just as well to replace it. The price of the two plugs will be high. Not only that you will lose your water proofing with most replacements, a new cord will probably have molded plugs.
Problem could have been low voltage but most likely the plug came loose one time. Once it starts to melt, burn, it would get worse every time it was used. This might have happened two or three times ago, no way of knowing. If it was low voltage then a "protector" would have saved it. As voltage drops currant usage increases Higher currant, higher heat. A loose connection is now more likely to start burning. Again, no way of knowing when.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-20-2015, 02:16 PM   #15
For some info about surge protectors look at this thread.
decent 30 amp surge protector
Just started this thread a day ago.
Jim
George Bernard Shaw
Old 07-20-2015, 03:42 PM   #16
Ham Camper's Avatar
Progressive Industries is the best. I bought one of their hardwired EMS units and had a few problems getting it installed. They could not have been better, answering all my questions and really "caring" about their customers. The lifetime warranty is also another great thing. They are not cheap but in this case u get what u pay for. I highly recommend them.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 07-20-2015, 04:04 PM   #17
jk510's Avatar
As Ham Camper suggested get the Progressive Industries hardwired unit if you can. The portable would be the second choice. If possible get the unit with the remote display. It's a little difficult to run the wire for it but you can keep tabs on how the power is doing.
Also be careful when shopping around. I found some pretty cheap prices when shopping for mine. I think the cheap one are Chinese rip offs. Beware, they look the same but are not warrantied and well, you get what you pay for.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 07-20-2015, 06:46 PM   #18
Originally Posted by Lloydg View Post
I agree with your comment but I hate to confuse spudston with sematics, but here is the description of my "Surge Guard" which is similar to the "Progessive".
"shuts off power in the event of an open ground or thermal line/load overtemperature condition, as well as in the event of an open neutral, low (under 102 volts) and high (over 132 volts) voltage or reverse polarity to protect your RV and its electrical components from damage and fire. Continuously monitors for voltage and amp draw (RMS) and reverse polarity (miswired pedestal or elevated ground voltage)."
A surge protector may have saved him from his misfortune. Much time on the forum and one can see campgrounds that have all sorts of power problems. I always use mine and was just trying to help him to understand how he might be able to protect this from happening again.
Thanks for your explanation of the "Surge Guard" (which is similar to "Progressive"). We, too, have a Surge Guard and have read so much about PROGRESSIVE that we were worried we didn't buy the right product until we were saved from not one, but two, campground pedestals. The fact that both do a good job means a lot!
SkipnTerri is offline   Reply With Quote
Old 07-20-2015, 08:44 PM   #19
Timex's Avatar
Confession from a long time ago
I was a nube many moons ago. On my previous TT we stayed at a SP that had only an outlet mounted to a post. You notice I didn't say 30 amp outlet. I was very uneducated way back then, I'll admit.
Hey, there was a plug to plug my cord into and I was happy. Had to use my adapter because my cord end(30 amp) wouldn't fit in the plug. Are you following me? Yes, I plugged into a 20 amp outlet.
Yes, it was hot weather, and I used my AC.
Yes, water heater on electric.
Yes, fridge on electric.
Yes, several lights on.
Yes, TV, etc...
Why the breaker didn't trip before the BOSS used her hair dryer has mystified me for years.
I was way over 20 amp usage and even over 30 amps.
When I unplugged, the adapter was melted and busted almost in half. The cord end was melted too. I had an electrician replace the cord end and a couple years later, he had to do it again. The cord was apparently wired into the converter because I pulled the cord out of a compartment thru the exterior wall. It was probably damaged on the inside end as well.
Since then, in present time, I have been educated by my brethren on FRF on proper use of a power cord.
I first, before plugging in anything, check the pedestal for any irregularities with a circuit tester and a plug in voltmeter.
I use a little dab of dielectric grease on the pins of my PI surge protector before plugging it in and letting it run it's diagnostics.
ALWAYS HAVE THE BREAKER OFF BEFORE PLUGGING ANYTHING IN OR UNPLUGGING.
Dab dielectric grease on the male ends of the power cord and also on the pins of the RV receptacle.
About once a year, or more if needed, I'll clean the pins with a light grade sand paper.
But like others have said, the plugs should be tight. If it is loose, you're inviting trouble.
And yes, I would replace the cord.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 07-20-2015, 08:45 PM   #20
I had mine burn up also and had to put both plugs the on the camper and the cord. I then put dielectric grease on the replacement.
NorSnrub is offline   Reply With Quote
