Old 11-18-2019, 12:22 PM   #1
Is there an in-line fuse??
Hey Guys,
I changed my house batteries a couple days ago and now I don't have power to my front cabinet where I turn on the satellite dish and the antenna. Is there a fuse I should look for somewhere to that cabinet?
I own a 2011 Coachmen Cross Country 405K.
I can't remember ever having this problem before.
Any help will be highly appreciated.
Take Care!
retiredchief is offline   Reply With Quote
Old 11-18-2019, 12:38 PM   #2
Head Rambler
Do you have 12 volt power to all the lights and devices other than those in that cabinet?
Have you looked in the power center to see if there's a fuse labeled for those items or something similar.
Gotta go campin!
Old 11-18-2019, 12:47 PM   #3
Yep I've got power to everything....I've checked all the fuses I can find and haven't found any bad ones. I was wondering if there is an in line fuse somewhere...
Thanks for your help!!
Old 11-18-2019, 01:10 PM   #4
did you check your circuit panel mine is 110 and 12 volts ?
cfo111 is offline   Reply With Quote
Old 11-18-2019, 01:39 PM   #5
My coach is 50 amp. I've checked everything I can think of...still scratching my head. 😁
Old 11-18-2019, 01:44 PM   #6
what has that got to do with check the power box I also have a 50 amp and I have 12 volt fuses there. ?
Old 11-19-2019, 01:42 PM   #7
DouglasReid's Avatar
Have you checked for any resetable fuses/breakers near the battery?
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 11-19-2019, 02:10 PM   #8
aren't the satellite dish and antenna 120 volt devices? if so changing the battery would have no effect. try looking at 120 circuit breakers or a tripped GFCI.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 11-19-2019, 02:18 PM   #9
If so why not test the plug to see if power if 120 volts in panel. But all this is useless if you get not replays.
fuse
