Old 05-30-2012, 02:15 PM   #21
Doesn't look like you have room to put it where I mounted mine. I would try behind the tanks using a piece of sheet metal bent into a bracket shape.
Len & Cheri is offline   Reply With Quote
Old 05-30-2012, 02:24 PM   #22
Triguy's Avatar
Originally Posted by MilCop4523 View Post
Ok lets attempt this again....
I purchased the Blue Sea 9001e e-Series Battery Switch Selector locally - just under 58 bucks taxes included.
Where to put it?
There is no sturdy brace under the propane tanks like some units.
The only place I can find for fitment is at the location marked in red (sorry for anyone colour blind I didn't think of the colour before it was marked) - other than that I can get a piece of Aluminum plating and attach to to the underside of the tank pan (extinguish smokes, remove propane tanks second and drill third - right?)
I have seen them installed on the outside of the frame. A guy I met likes to be able to see his so he can tell easily if its battery 1 or 2, both or off. His was on the other side of his frame so he could see it from the "door side" of his trailer.
If you don't like the outside, what about inside the frame?
I drew blue boxes on your picture for what I mean.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-30-2012, 02:27 PM   #23
MilCop4523's Avatar
I'll look at the places tonight if I get a chance. Thanks for the suggestions
I thought of the inside rail.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 05-31-2012, 02:49 PM   #24
bob213's Avatar
I put mine on the thin pan below. Why does if have to be some strong piece of material? it's not heavy or load bearing. I like it on the propane plate because it's out of the weather.
bob213 is offline   Reply With Quote
Old 06-01-2012, 08:18 PM   #25
sherdep's Avatar
mine is mounted on the thin piece of metal that is vertical just under the propane tanks like stated above. I used teflon nuts so the nuts would not back off with out assistance
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-04-2012, 07:51 AM   #26
MilCop4523's Avatar
Got'er DONE!
4th mod/repair to the trailer.
In line invertor protector - 1st,
RVQ - 2nd
Grey water drain from the Galley - 3rd
and now this.
I didn't want to drill into the frame if possible so I went to the salvage dealer Saturday (after getting almost home) and picked up some
1 1/2 alunimum square tubing to redo my braces on the air deflector
and a 6 by 6 piece of same for the switch.
Got home and started to assess the job.
Removed the 30 lb'ers
Removed the electrical and gas lines to a safer location.
Got the 18 volt drill
safety glasses
clamps and measuring tape.
All set.
Except for a scribe. where did the scribe go. There's never a scribe around when you need one (wait thats a cop - sorry wrong blog)
Marker located.
Now in orer to center the 6 inch bracket on the battery rail take the 13 inches divided by 3 to center the 6 inch plate. Thats 2.5 on the left side, and 7 on the right side correct? That didn't seem right.
Shoot for center mass and line up the 6 inch plate in the center.
Math never was my strong point - I only needed to remember how many rounds went into the Sig 226 and that a man with a knife at 21 feet could out run my drawing the firearm from my holster and getting a round on target.
Now I have to get the connecting lines and hook it all together.
And I have to find a loop for the propane line to bet bolted to the edge to stop the plate from rubbing through. I might have one on the old Honda motor cycle in the barn. Just gotta sneak past the 30 lb racoon and the 2 skunks to unhook it.
That may be repair mod no. 5
ID:	14783   Click image for larger version
ID:	14784   Click image for larger version
and
Old 06-07-2012, 07:12 AM   #27
sherdep's Avatar
MilCop - nice clean install
the only issue I would think with the way you mounted it is that water and rain can now pentrate the switch especially when you pull the center switch out - even though it says it is waterproof.
Here is the one I just ordered and will be switching out my single switch
P/N 6007200 - M Series Battery Switch Selector 4 postion
m-Series Battery Switch, Selector 4 Position - PN 6007200 - Blue Sea Systems
it is similar to the one you installed except mine is black and it has a back cover to keep the wires from being shorted out against the frame in case it is ever smashed
Old 06-07-2012, 11:19 AM   #28
FreedomTracker's Avatar
I keep reading posts about the battery disconnect switch modification and now interested.... I currently just have 1 battery on my MiniLite TT (small box).
  1. What disconnect switch would you recommend for someone who has 1 battery but may upgrade to 2 someday?
  2. How hard is the electrical installation? Is it just the outside battery cables plus mounting?
  3. What circumstances would I want to add a 2nd batterry? Not "currently" boondocking. Still a benefit?
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-07-2012, 01:09 PM   #29
MilCop4523's Avatar
Thanks. Now I have to go looking in the garage tonight for something I can make use of as a cover. Since I think I have just about everything everyone else would have tossed out in decades gone by, I suspect it will be an easy find. I just have to remember where the things may be.
The new unit looks like an upgraded model and most likely woudl protect the wires as you have considered - most likely from an accidential bump ie. kids or adults hitting it. But anything bigger than that smashing it, I'll see everyone in heaven because the propane tanks will send me off like a rocket.
and
Old 06-07-2012, 01:16 PM   #30
Triguy's Avatar
1. You can buy an "on-off" model such as the Blue Sea 6006m or one that allows you to select battery bank 1 or battery bank 2, or 1+2. If you know you will add a second 12-volt, than buy the Blue Sea 9001e or one like it.
2. Easy. You will need 4/0 AWG cable per each battery terminal in addition to the disconnect. The position on the trailer can complicate matters depending where you install it. But generally pretty straightforward install.
3. Its all about capacity and your power usage. You don't need a second battery if you are always on shore power. I turn the question around to you, "why do you think you need a second battery?"
Scott
2012 Shamrock 233S
battery, battery disconnect, led pad
