Old 05-24-2012, 08:03 AM   #1
Is this battery disconnect too big?
Amazon.com: Blue Sea Systems 9001e e-Series Battery Switch Selector: Sports & Outdoors
The specifications say this switch is 3x6x9 inches. That seems awfully big to me. The pics look like it would be smaller with two of the dimensions being the same. I would like to mount it inside the battery box with the switch on the outside. Anyone know if these dimensions are correct? I'm wondering if maybe that is the dimensions of the package it comes in?
comfun1 is offline   Reply With Quote
Old 05-24-2012, 08:10 AM   #2
Herk7769's Avatar
I used this switch and the dimensions are wrong.
e-Series Battery Switch, Selector 4 Position - PN 9001e - Blue Sea Systems
more like 3.5x3.5x2 you will need the depth for the heavy cables.
HAM CALLSIGN - KC3FFW
Old 05-24-2012, 08:12 AM   #3
Triguy's Avatar
From the manual:
File Type: pdf Blue Sea Battery Disconnect 9001 E-Series.pdf (271.0 KB, 20 views)
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-24-2012, 08:18 AM   #4
Those dimensions have to be wrong
Name:	Battery shutoff.jpg
Len & Cheri is offline   Reply With Quote
Old 05-24-2012, 08:33 AM   #5
I was planning on mounting the switch inside the battery box with just the selector knob on the outside, would there be any problems with that?
Old 05-24-2012, 08:35 AM   #6
Herk7769's Avatar
I think your battery box will be too small unless you have a size 27 box and a size 24 battery.
Old 05-24-2012, 08:44 AM   #7
Triguy's Avatar
I mounted mine to the tongue within 12" from my battery. These are made for marine applications and are rated for strong water jets, spray, etc so no problem exposing them to the weather.
Scott
2012 Shamrock 233S
Old 05-24-2012, 08:45 AM   #8
Won't fit - as per Herk's comment above. I have that switch and mine is mounted on the outside of the battery box, with the cables running through the battery box lid channels.
...VTX-Al
VTX Al is offline   Reply With Quote
Old 05-24-2012, 08:53 AM   #9
I was planning on a bigger battery box I saw at Walmart and the battery that came with the camper is in a smaller battery box. I guess that now that I know the dimensions I can measure the battery and box and see if it will fit. I thought I would use the smaller battery box for a second battery.
Old 05-24-2012, 10:03 AM   #10
I have kinda thought about doing this and some of the other mods (like remote awning...) but I was wondering if you thought it would void any of the warranties on the trailer doing stuff like this? Or should I wait till all the warranties run out?
thanks.
merlin66043 is offline   Reply With Quote
battery, battery disconnect, led pad
