Old 07-27-2016, 06:56 PM   #31
dannyabear's Avatar
Originally Posted by ShermanD View Post
Got a solution for you. Go to your local HD, Lowes, True Value, etc and get yourself a 30 amp 4 wire dryer cord and a female cord cap configured to whatever your RV needs are. If you need 125/250 volts use both hot wires. If you only need 120 volts use only one hot wire and tape the other one off.
Next year find a annual with a newer service
This is a good temp solution, I have the know how and would change the dryer recepticle or just add a 30 amp rv rect. to the box.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 07-27-2016, 07:03 PM   #32
dea49's Avatar
Originally Posted by Steve29rlx View Post
Has the fuse ever blown? Do you have a spare?
There is probably a penny screwed in behind it.
dea49 is offline   Reply With Quote
Old 07-27-2016, 07:14 PM   #33
Originally Posted by gectisme View Post
I believe the outlet with the horizontal blade is rated at 20amps, (the one the OP is plugged into). I would do as other said, if you don't have the know how and tools, pay an electrician to change it out to a 30amp outlet, shouldn't cost too much and get peace of mind...
You are right 30A would be two horizontal blades my bad
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2016: 19 nights
Miles traveled in 2016: 2,575
uhduh camping is offline   Reply With Quote
Old 07-27-2016, 07:38 PM   #34
The 110 v plug is a 20 amp receptacle.
The extension cord does matter. The bigger and shorter the better. You loose amps per foot.
As info
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd
2014 Jeep SRT...did not trade
Simplewon is offline   Reply With Quote
Old 07-27-2016, 07:45 PM   #35
OntarioFireFighter's Avatar
Originally Posted by Iwritecode View Post
That doesn't sound right to me but I'm like you and know very little when it comes to electricity and how it works. I'm sure others will chime in if that's even possible...
The 30A fuse protecting the 20A outlet, is incorrect; and dangerous.
The "T-slot" outlet is rated for 20A... that's what the fuse should be, at most. The contacts, and most likely the wiring, isn't sized for 30A loads. Running it at 30A is a bad plan...
The whole works should be redone, IMO.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2015: 37
Nights Booked 2016: 44
Nights Camped 2016: 41
OntarioFireFighter is offline   Reply With Quote
Old 07-28-2016, 03:06 PM   #36
Originally Posted by BamaBob View Post
Also I forgot to attach the EMS photo - oops here it is.
Bob, that is the exact EMS I have. YAY!
I emailed the owners asking for an updated box that I can directly plug my 30amp plug into, that also has a circuit breaker.
They agreed to replace it. The last renters on this site were there about 15 years, and they told the owners they didn't want it replaced, because they liked having the second out for plugging in lights, etc.
The new box will NOT have an additional plug.....but I'm fine with that. I can use the plug on the outside of my camper for those needs.
Thanks to everyone else for their input. I hope this helped others too.
Thanks! Mike and Jan.
2016 Forest River Surveyor 32RLTS
(Newbies: Our first camper. No truck. Permanent campsite in Pocono Mountains, PA.)
PoconoFun is offline   Reply With Quote
Old 07-28-2016, 03:12 PM   #37
If you have a 50 amp camper ask for a box with a 50 amp plug.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 07-28-2016, 03:41 PM   #38
Our camper is wired for 50amp in case we later want to add a second A/C.
But the campground does not offer 50amp service to the seasonal sites.
I've not had problems with 30amps except on the holiday weekends.
Old 07-28-2016, 03:49 PM   #39
BamaBob's Avatar
You are now, as we say in Alabama "In High Cotton"
Enjoy your new (and SAFE!) Electric pedestal (At no cost to you! )
Now....
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is online now   Reply With Quote
Old 07-28-2016, 04:12 PM   #40
Originally Posted by dea49 View Post
Post a pic of the wiring. It is usually a simple setup with a positive, GND, and one lead for each tank.
It is fairly easy to pull a wire from the connector and using a flat blad screwdriver, reinsert it in the proper one.
The plug they say is 30A doesn't look as though it would be UL listed for that type of amps and will eventually heat up and fail. What is the blade configuration of your power cord?
Here's a picture of the back of the tank panel numbered #1 (red) to #6 (blue).
electric, electrical
