Old 07-24-2014, 08:21 PM   #11
Plain Old Member
Sounds like you have a bad breaker. Doesn't happen often, but does happen.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-24-2014, 08:26 PM   #12
Plain Old Member
Might sound crazy, but.... Same problem. AC only thing running, breaker installed next to 30 amp main. 30 amp was tripping. Moved the AC breaker over a couple of slots (swapped it with something else), and 30 amp never tripped again. It was a shot in the dark, but it worked that time.
Problem with yours is, I see that it's one of those breakers with the 20 / 30 together.
Old 07-24-2014, 08:30 PM   #13
I have been in the electrical maint industry for 35 years with a power company. Typically breakers will get warm as they reach their rated capacity. Now if it "HOT" as you described, and it tripped, it may indicate an underlying problem. Most "HOT" breakers result from BAD connections. If a connection is loose, it will require more amperage to do the same amount of work, that a tight connection would.b If all the connections are tight and in good condition it could be a faulty breaker, whereas the connections in the breaker are not "making" up properly. This is no where near as common as a loose connection. Hope this helps. Paul
"DON'T FORCE IT - GET A BIGGER HAMMER'
"Paul & Laurie"
2013 Columbus 340 RK
2013 F350 Dually 6.7 Diesel
Paul M is offline   Reply With Quote
Old 07-24-2014, 08:35 PM   #14
B and B's Avatar
Both Big John and Paul have vaild points. I would move the breaker. Also make sure connections are tight. Third thing is the water heater off and fridge on propane? The voltage may be low meaning a AC unit current goes up along with anything else die to lower voltage.
At our park model and temp is 60 right now! No AC required.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-24-2014, 08:48 PM   #15
Another good point from B and B. If the volttage is low, it will ALWAYS increase the amperage. More amps = More heat. Maybe someone at the park can check the voltage. More time than not there is nothing they can do about it. I know in our industy, when there is a high demand for power, and not enough of it to go around, we will do voltage reductions on the system. This is not to inconvience people but to keep the grid stable. Better to have a stable grid (albiet low voltage) than no power at all.
"Paul & Laurie"
Old 07-24-2014, 08:49 PM   #16
BamaBob's Avatar
Originally Posted by JCamper View Post
Thanks for the suggestions all! I have fans blowing and the breaker box opened. Just sweating it out here. I can only get this rig down to 88 degrees today with it being 108 outside right now. Where's the pool...
Did not see if you said do you have 1 or 2 A/C? Can you add a A/C to your unit - if so this is the answer.
Really impossible to stay cool in the SW in the summer in a 30AMP 1 AC unit (We know because we lived in NM for 15 years)
Fans and swimming pools are your friends and if you are a handy person here is a DIY project you will WANT to do - cost ya all of $15 per unit
Hope this helps!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 07-24-2014, 08:57 PM   #17
BamaBob's Avatar
Originally Posted by Still Kickin View Post
Or not. Science wins and no this is not a invitation to a flame war
Global cooling - Is global warming still happening?
Old 07-24-2014, 09:17 PM   #18
dcheatwood's Avatar
A way to help your ac cool down your TT is to hose down the roof and walls is direct sunlight. If cg will allow, spend 20-30 minutes running cold water over the roof and especially any walks that have sun shining on them. And put sun screens in windows that sun is coming thru. You know, the big reflective auto windshield screens available at Walmart and other dept stores. Helps the ac maintain cool better. Make sure ac filter is clean also. When all else fails, drive to higher altitude. : ')
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-24-2014, 09:33 PM   #19
Blackrock's Avatar
Here at home here in sunny southern Arizona it was 109 and I had a contractor putting new A/c in the house. My wife and cat escaped to the TT for refuge but along about 3pm the temps in the TT were up into the 80's.
Got the house a/c job completed but it still took several hours to get the house inside temps back down.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-24-2014, 10:24 PM   #20
JCamper's Avatar
Talking
We have the Surge Guard protector at the pedestal so I'm assuming the voltage isn't low requiring more amps. Otherwise the protector would shut down as a safety measure. I looked at a Lowes for a new breaker but they didn't have the one I needed so I'll hit HD tomorrow. Better to replace it and make sure all connections are tight.
Dry ice in the fridge and in front of the fans works great!
Think the only answer in this heat is a 2nd AC unit.
We wanna stay for the Blue Angels flying tomorrow then we're heading for cooler locations. Thanks all for the suggestions and support!
JCamper is offline   Reply With Quote
