Old 07-20-2016, 05:58 PM   #31
Originally Posted by youroo View Post
I am going to take a "WAG" that you mean "Generator"? Start at the Top with a HONDA and work down to your price level,results and NOISE will follow the Price point! Like W/D says you will need Elect adapters! If your unit is 30A you could/will need "At Times" a 50 to 30,a 30 to 20, if 50A you will also need "At Times" a 30 to 50! And you will always need a Extension Power Cord, most of the Time a 30' 30A Cord will suffice with the proper adapters! Youroo!! PS and always have a Tester for the Power Supply that you are going to Plug into! Better "Safe than Sorry"!
X2. Can't go wrong with Honda or Yamaha. Quiet, start instantly every time.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags.
2011 28RKS Wildcat. Yamaha 3000iseb Generator.
2013 22 nights.2014 57 nights.2015 116 nights +14300KM
2016. 96 nights
Filterman is online now   Reply With Quote
Old 07-20-2016, 08:38 PM   #32
I currently have a Honda EU2000I that I converted to run on Propane. I just plug in the quick connect gas on the TT and off it goes. I don't have to worry about carrying gasoline or spilling it. It is also cleaner burning and the Generator will/should last literally forever. Because I can't run my air conditioner on 1600 watts, I need to purchase a 2nd EU2000I, convert it to propane and use the companion cable to get the power I need. If it isn't too hot I will just us one. MW and I like wooded sites at state campgrounds and we have found that many don't have power or water. So, I believe this will be a very workable solution. I haven't yet purchased the second Honda. JMTC!
SecurityRich is offline   Reply With Quote
Old 07-20-2016, 08:44 PM   #33
NMWildcat's Avatar
Originally Posted by spock123 View Post
I would be careful about heat build up. That must be one heavy generator. My two Honda's weigh 47 lb apiece. You buy what you like. I have had my Honda's for eight years. I use them at my house some.
Sent from may iPhone using Forest River Forums
I agree with Spock and youroo, start with Honda inverter generators and if you can't afford that work your way down to the cheaper inverters like champion. Do NOT buy a contractor type, you will regret it for reasons of noise, weight, gas consumption, and lack of clean power. Do your homework and research what the cheaper inverter gennies will cost in the long run. We have had our 2 Honda eu2000i for 10 years with no problems. Our friends who go the cheaper route buy new generators every couple of years. Good luck!!
NMWildcat is online now   Reply With Quote
Old 07-20-2016, 08:45 PM   #34
Who Dares, Wins
doc73's Avatar
Originally Posted by Havasu Bill View Post
I have the twin Honda 2000 package. I can run an AC with both running or just run one for basic utilities.
Same for me
Sent from my Samsung Galaxy S7
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 07-20-2016, 09:29 PM   #35
Yamaha or Honda inverter generators. They cost a bit more than the Chinese made ones but they last forever. Regardless of what brand you buy stay away from gas with ethanol. One thing I've learned in my long life is that ethanol is poison to a small engine.
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 07-21-2016, 11:05 AM   #36
The Honda and Yamaha are definitely at the top but for the 2000 models I give the nod to the Honda only because the Yamaha is not compatible with PI EMS.
If you ever get an EMS (PMI is very popular) you will want the Honda.
I bought the Yamaha's before I knew this. Not a big deal but would have selected the Honda's if I knew better.
I thought we would be boon-dockin it and need them right away, but they've been sitting in the box in my garage for 8 months. So far, we've only stayed at campsites w/full hookups.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 07-21-2016, 11:14 AM   #37
RSchleder's Avatar
This post is a bit off subject, however, there's a lot of great info here.
New RVer
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-21-2016, 11:32 AM   #38
Generators- something I know a little about (I have 4 of them)
I have a built in generator in the RV which is 4000 watt and it powers everything in the RV if you want to use it. The drawbacks are that it is noisy inside and occasionally you can smell gas fumes (after all it is gas and runs right there by the window). We don't like to use the generator in the RV. 5 years owned and like 50 hours on it.
If you do much dry camping, beware that where you are going even allows generators. And if they do, what hours they allow them. Most do not allow running them at night which is when you might need some AC at about this time of year. Even some KOA's are restrictive about generator use (because they want you to upgrade your site naturally).
My brand of preference is the Powerhorse sold by Northern tool. On sale it is a real buy and the bigger ones have 220V plugs. Their smaller one- the inverter/generator- sells for like half what the similar Honda sells for and several hundred less than Generac. It will not power the AC but is the only small generator of its size that I have seen that accepts a 30 amp plug and can be hooked together with a twin easily to power all your needs. My wife and I camped the Smoky Mts. this spring for over a week, no electrical anywhere in the park, and the small one was fine. It recharged the batteries of the RV, operated the fridge, HW heater, and other stuff while it was running. It is very quiet and a real gas miser. It is no bigger than a small cooler and is about that heavy.
I do recommend getting a 30 amp extension cord (sold at Wal-Mart and Amazon) and you have to get an RV adapter. If you need 50 amp, you need to get a bigger generator and the Powerhorse 9000 is a beast. But it is not quiet. None are at that output level.
All the best of luck to you!
YoBobH42 is offline   Reply With Quote
Old 07-21-2016, 12:04 PM   #39
D_B Travelers's Avatar
And...they are gone
Has anyone else noticed the OP has left the building? We are entertaining ourselves per normal anyway!
I bought two of the Ryobi i2200 inverter generators and the cable to connect them for full 30 Amps. They are about 1-2 db louder than the gold-standard Hondas but saved me $1,000. I find they do fine with the Wind Jammer, as long as you don't turn on the main 15K AC unit and run with the 13.5K.
D_B Travelers - 8 nights in 2017, 35 nights in 2016. [U]1st love: 2014 TT WJ3001w, now 2016 FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 07-21-2016, 01:28 PM   #40
V-Lite Fun's Avatar
I have a 2000W Powerhorse from Northern Tool. It is as quiet as a Honda and half the price. I only use it to charge my battery when I'm off grid for a few days. Look one up and read the reviews.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
generator
