LE2150 no clearance lights
I have a 2015 LE2150 Prism which I just set up to pull my 2011 HHR. I used a Demco wiring harness to hook up the tail lights and pulled to the front of the HHR and hooked up to with a 4 prong plug. It is also hooked to an SMI Stay in Play braking system which works fine. Fired it up and everything worked just fine. After a shakedown cruise pulling the car I noticed there were no tail or clearance lights, but turn signals and brake lights were fine. The HHR had a burned out fuse, but I have not figured out where the fuse for the tail lights are on the LE2150. I looked at the Mercedes fuse guide and there is nothing that sounds like a tail, clearance etc. fuse. I looked on the forum and read some Solera posts which talked about some fuses that Forest River has somewhere back by the waste tanks, I followed the wires but do not see where a fuse box could be in that area. Another post talked about the problem being in the Mercedes circuitry. My Mercedes dealer can get me in 14 days from now. After I get the Mercedes fixed I am wondering if having both vehicles running when I hook up the wiring can cause a problem?
