Forest River Forums
Sunline User Photos
Old 02-06-2012, 07:25 PM   #1
Leave Battery connected during storage?
We just bought our first TT, moving up from a popup. We had a great first trip in it this past weekend. Now that its home I'm not sure what to do with the battery. I have the TT plugged into shore power and the converter appears to be trickle charging the battery at 13.7v. Should I disconnect the battery to avoid overcharging or will it be fine to remain on trickle charge?
Thanks,
Bruce
2012 Avenger 26BH
bwbarnes is offline   Reply With Quote
Old 02-07-2012, 10:04 AM   #2
Included in your RV info pouch there should be an owners manual/pamphlet from the converter manufacturer. It will tell you if the converter has a 3-stage charger built in. If it is a 3-stage you are fine to leave it plugged in.
...VTX-Al
VTX Al is offline   Reply With Quote
Old 02-07-2012, 10:09 AM   #3
Dave_Monica's Avatar
Iv'e had my camper plugged into shorepower all the time it's at home for the last 4 years. No problem.
Dave
2008 F250 CC SB 6.8L V10
2010 Rockwood 8280WS
Nights camped in 2010 - 58, 2011 - 43, 2012 - 20
Old 02-07-2012, 10:16 AM   #4
Moderator
Triguy's Avatar
Its fine to leave it plugged in assuming you have a three-way converter/charger, which you almost certainly do. Check the water level in the batteries periodically.
However, you can also disconnect the batteries if you do not intend to use the camper for a month or two. They will remain charged as long as they do not have a draw. That's why many of us install a battery disconnect switch.
Scott
DW, DD's x 3 and Murphy the Camping Dog - A Golden
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD, P3, Equal-i-zer
Triguy is online now   Reply With Quote
Old 02-07-2012, 11:07 AM   #5
I have always left mine plugged in at home. Never had a problem. I typically get 4 to 6 years out of a battery, so it must be okay to do so. I do check fluid levels in the battery often and fill as nessasary. I leave the batteries in my boat on a trickle charge all year long and have never had an issue with them either.
rkswyo is offline   Reply With Quote
Old 02-07-2012, 02:29 PM   #6
You will be fine. I have the battery disconnect switch also so I never have to unhook the battery.
jrlehr is offline   Reply With Quote
Old 02-07-2012, 05:49 PM   #7
Thanks everyone. I checked the manual for the convertor and it is a 3-mode unit. So it is in float charge mode right now, happily maintaining the battery.
Bruce
2012 Avenger 26BH
Yorktown, VA
Old 02-07-2012, 06:06 PM   #8
too fast turbo sled
f1100turbo's Avatar
I leave my 5er plugged in to shore power 24/7 365 no issues.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 02-07-2012, 09:32 PM   #9
Anacortesians
We keep our GT 325 Class A plugged in all through the winter. It's moored alongside the garage. So far (second season) we haven't had any house battery issues. We have two Costco deep-cycle 12V marine/RV batteries in parallel. They were new in July 2010 just after we bought the rig.
When it's time to resurrect it for next season, about 8 weeks away, who knows what surprises await!
Frank and Eileen
1 Rescued Male Labrador - Bailey, 9 in July
02 Georgetown 325, F53 V10
Old 04-13-2012, 08:59 AM   #10
Tiny solar panel on top of AC
Hi all,
I just bought my first RV a Wolfpack WP32 to haul my bike and sand rail to camp. Love it so far. Not new, a 2007 model.
I live in a condo so no shore power available. There is a small approx 12x12 solar panel on top of the AC unit. I have no documentation at all. By experiment I have found that with no shore power or tow vehicle connected the voltage is higher with the battery disconnect "ON" so I assume the solar trickle charger is working. Voltage dropped when I disconnect. I was not sure if the solar would still charge and the disconnect was just to remove the leakage current for LPG detector, etc.
I bought 2 new Group 27 deep cycle batteries and connected in parallel. My idiot light panel just has 4 lights for battery condition and now after about 3 weeks seems to have settled at 3 lights. I measured at the battery connections and it was sitting at 12.3 volts. With the LPG detector going is this probably all I will get out of the little solar panel on top? I live in sunny St. Petersburg, FL so get a lot of sun.
Should I think about disconnecting the LPG detector. Nothing else is draining power. Maybe 12.3 is fine and when I tow a couple hours camping the truck connection will top off the batteries.
Also when I hook up shore power camping should I disconnect the batteries? Not sure if I have 3-stage converter.
Thanks all. This is awesome to have so much information at hand.
Dave
41railbuggy is offline   Reply With Quote
» Online Users: 544
124 members and 420 guests
0721SSROO, 4bnabird, 4Jeeperz, acadianbob, accumack, armye7, ashump, ayotte, BBuck, biggrigg, BigKidzFun, bignugget, BOBFIDY, briangoodridge, buzzmonster, Cafjackracing, caper, cat1956, CHD Dad, chof16, comfun1, Cowracer, D-mo, DAISY BOYKIN, darkcloud, daveg, daw592, dewcew72, dezeldad, DonCath25ds, DonG, donn, dtolar, dunnnc, Elidh, Emptypockets, etbt1216, extremebike, Falcon35, flc, Flying dutchman, FR28footer, frfan, gerrym51, Great Horned Owl, gtkato, gvanmeter, herk7769, hitch hiker, hoovercab, Indy Steve, Itsthetwoofus, J McClure, Jeep4Two, Jestercyco, jjm901, JMF, jmswms, JoeR, jusme, ken0042, kgmat, KKapa, Kricket, lbhird, leencharlotte, lemoj1, LFugate, lmcleister, Lonewolfcry, lowbubba, mayorvic, mcbride5, merlin66043, mike7431, MikeFresno, MilCop4523, Mkayers, Mnflyboy, mrtodds, msbates, NanaKaren, NeilM108, nuisance, OffPavement, pg_rider, Pinesman, pmsherman, pwrplay, redfox217, Reneedann, retiredguy, Rickstermn, Rugged Brown, rvinman, SabreSam, Sailfish Bret, Sawdr73, shineysideup, slogan, softwarejoe, southernsky, Stank Bait, Tbeasley77, Tee, tentcamper1, tessval, THELMALOUIE, tiny, tking01_2000, torben, TRAVLINOHIO, travyp, Triguy, tshayn, vlite2011, vp22er, wagon52, whj77372, wildwood_man, wnytaxman, wolfpack21643, wpmcnutt, youroo
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
