Old 01-26-2016, 02:00 PM   #21
Too Tall's Avatar
With the parasitic drain, you have to leave them on some kind of charger or disconnect altogether.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-26-2016, 03:31 PM   #22
uphillracer's Avatar
I leave our TT plugged in 24/7 because I also run a de-humidifier inside 24/7. Never a problem.
uphillracer is offline   Reply With Quote
Old 01-26-2016, 03:50 PM   #23
I use a pair of 6 volt golf car batteries and top them up each month even if just a drop or two. Just be sure not to overfill and try to use only distilled water.
kenenn is offline   Reply With Quote
Old 01-26-2016, 04:41 PM   #24
Ex telco
Being an ex telco worker I tend to be overprotective of my wet cell batteries. Part of my winterization process is to remove the battery and bring it into the garage. Keep it on the bench, top off the water, charge it up and put it on the trickle charger (Harbor Freight about $8). Makes em last a good long time.
Strigflag is offline   Reply With Quote
Old 01-26-2016, 04:50 PM   #25
I would not advise it!
Originally Posted by Grandad53 View Post
Hello friends! I am fairly new at this and have a brand new 2016 Forest River Vibe 268 RKS. The question in my mind is: should I leave it plugged in to the 120volt service over the winter? Nothing is on inside but was wondering if it keeps the batteries topped off while plugged in or if it is actually bad for the batteries. I don't want to cook them dry but, if it doesn't trickle charge them at all, no need to keep the microwave clock functional. Thanks for your knowledgeable replies!!!
RV's of this class that have the factory converter/charger are low end (had to change/upgrade mine) as the low end models the factory installs do not have the proper type of charger to just leave plugged in and forget. They can damage the battery if left alone.
So i would just unplug the coach, take out the battery and put it in your basement (or somewhere warm and dry) it will freeze pretty easy, with a float charger clipped on it the battery, and just reverse the process in the spring (or month) when you leave again.
Hope this helps and Happy Camping
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 01-26-2016, 05:08 PM   #26
Filthy Beast's Avatar
My batteries are now 8+ years old being maintained by the "low end" converter, plugged in 24/7 and they still hold a charge. We camp without hookups half the time and the batteries still perform well. I do keep the water level up, but only have to add a couple of times a year.
Goody Two Shoes and the Filthy Beast
2008 Chevy Silverado 2500HD
Duramax and Allison 6 speed
2012 Wildcat 282RKX
You can't make things idiot proof, you can only make them idiot resistant.
Filthy Beast is offline   Reply With Quote
Old 01-26-2016, 05:18 PM   #27
Boss Hoss's Avatar
Originally Posted by RSchleder View Post
Interesting! I've owned 12Rv's including 3 diesel pushers (Gulfstream, Monaco Dynasty, Allegro Bus), and have NEVER had batteries that didn't occasionally need water. Only batteries that I've owned in all my years that didn't need water now and then were "sealed units".
I'm with him!
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 01-26-2016, 08:16 PM   #28
We too leave ours plugged in 24/7 and so far no issues. Had this camper for almost 6 yrs now.
Donna=Me Tom=DH
2 DD's-grown, 1 DS grown, 1 DIL
4 DGD's, 1 DGS, 1 Pekingese(7/1/1999-6/18/2016)
2011 Shamrock 23ss
2000 Suburban 1500 4 X 4
ngts camped 2016-24 so far. reservations for 11 more
ilovecamping is offline   Reply With Quote
Old 01-26-2016, 08:56 PM   #29
MNtraveler's Avatar
Leave plugged in or not?
I see in this "owners manual" that it DOES charge the batteries while plugged into 120v power supply. I have no build sheet telling me anything about this particular power converter. I do not expect it to be sitting for much longer, perhaps less than a month so maybe it will be ok. Thanks for the advice!!
You really need to get the build sheet with the model number of your converter and all your other equipment. For the converter, that will tell you if you have the type that can be left plugged in long term during non-use (will automatically shift to float mode) or not. Or you can look on your WFCO for the model number and Google it. I see directly conflicting comments above as to whether this particular unit can or cannot be left plugged in full time.
By the way, you will have very little battery trouble with storage for one month. I really can't see where it's worth the bother of pulling out the battery. If in doubt, plug it in for a couple of days then unplug it. Two weeks later, repeat. Two weeks later repeat then hit the road. Check battery water levels each time.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 01-26-2016, 11:28 PM   #30
Too Tall's Avatar
IMO, if you are going to leave the battery (s) connected, they need to be on charge 100% of the time. I've sulfated a battery in less than 1 1/2 years by unknowingly charging and discharging it too much due to the parasitic drain. So given the alternatives, keeping it on charge all the time is what I do now. The WFCO is definitely not overcharging on my TT. I'm definitely going to put a disconnect at the battery so I can stop the parasitic drain however.
USMC 68 -70
