I have a 2012 Lexington. I made the jump to change all lights to LED. The problem; when I installed the dimmable bulbs I checked each one as I went thru all the fixtures to see if they worked, and each one worked until I installed the last one. Then all lights come on then go off. If I place the original incadessent bulb back into the last socket they all work properly.
I read on this forum somewhere that you have to replace something at the switch. What would it be and where can I pick one up.
Help me out guys. Thanks
I found a cure for replacing Dimmable LEDS for my 2012 Lexington GTS.
You must replace the dimmer control on the wall.
Here is what I purchased; Company- Aspect LED, Model AL-CTR-PWDIM60-W
Cost was $29.95 + shipping. Look them up on the WEB. You call them and explain your problem and theyre are very helpful.
