Old 12-10-2014, 06:55 PM   #1
LED Light Question
I have a 2015 CC Silverback 33RL and I have an LED above the microwave area that has gone out. It is a flat panel type with 5 lights and it seems to be soldered. Any idea what way would be best to replace this and where one can find this. It looks like it is from Bright Ideas LLC and model SL206M2, I did a search and did not see anything.
wcbledsoe is offline   Reply With Quote
Old 12-10-2014, 08:18 PM   #2
Rcbstuff's Avatar
Warranty should cover that
Rcbstuff is offline   Reply With Quote
Old 03-15-2016, 07:01 PM   #3
Same problem
I had the same problem with one of these. After six months and hardly any use, the led started to overheat and was on its way melting through the white plastic cover.
I've searched all over the web for a place that sells replacements with NO luck. If any one knows where I can buy these I would very much appreciate knowing.
As for warranty work, that is hardly practical. Eighty bucks for a service call, then the guy has to get FR approval, then find the part, and finally come back to install it. There's one process that just does not work. Better to buy it out of pocket and install the light myself.
SoCal-40cck is offline   Reply With Quote
Old 03-15-2016, 07:10 PM   #4
Flybob's Avatar
Contact your dealer. FR has had some issues with the round LED fixtures. They will send you replacements. It is worth a the call.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-15-2016, 10:15 PM   #5
Jimsue's Avatar
Tried replacing round incandescent with round LED in our 2013 Sabre and blew a
15 amp fuse every time it was activated. Could this be related to the "problem" referenced, and, if so, do you have more info or links to the issue? Any help is appreciated..
Jim.couillard at gmail
F350 lariat diesel
2013 Sabre 5th Wheel 31 RKOK-6
Demco Hijacker Hitch
2015 F350 Lariat Crewcab DPS SWD 4x4
2013 Sabre BKOK 31
Demco Hijacker Autoslid
Renogy Solar Suitcase
Progressive Industries EMS
Sea Eagle 420 Tandem Inflatable Kayak
Jimsue is offline   Reply With Quote
Old 05-06-2016, 07:37 AM   #6
I just checked with FR and their response was:
Those are lifetime warranty thru the supplier (Bright Ideas), but you have to contact them directly at:
Trent Wagner
Bright Ideas LLC
574-295-5533
tntbrightideasllc@gmail.com
I contacted them and they are shipping me a new replacement light. I just needed to email them a shipping lable and will need to return the defective unit.
tendashseven is offline   Reply With Quote
Old 06-19-2016, 10:59 AM   #7
Bright Ideas LED
I had one go out yesterday. etrailer.com is the only place I have found them.
https://www.etrailer.com/dept-pg-Tra...ght_Ideas.aspx
I'll contact Bright Ideas. Free replacement is better!
Bobby
bgview is offline   Reply With Quote
Old 06-19-2016, 03:35 PM   #8
Bright Ideas LED
Well, it ain't exactly free. You pay to have it shipped to you and you have to ship the old one back!
led, light
