Old 05-13-2012, 08:54 PM   #1
LED Lighting
Has anyone replaced their old bulbs with LED's
Is the light the same color or intensity
We were looking for a more muted light when we first get up in the AM and wondered if a set of LED's would make the diference.
C1v1leng is offline   Reply With Quote
Old 05-13-2012, 09:16 PM   #2
Triguy's Avatar
LED's can be as dim or as bright as your want them to be. We replaced all interior lights with roughly the same intensity and color. Those LED's described as "warm" will be closer to the color of an incandescent bulb. Those described as bright white or white will be bluish in color IMO.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-13-2012, 09:39 PM   #3
If your search for LED lighting on here, you will find a wealth of info. Topic has been covered, with pics, sources to buy from, current drain...... and the list goes on.
Of course if you just want dimmer light, there was a thread a while back, someone modified his fixtures with resistors to cut down the brightness. Might try searching for that also. Great site here, just got to dig sometimes to find the treasure.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
led, light
