Old 12-04-2019, 07:42 PM   #1
Led lights not working
Hello I have a 2018 Forest River Salem cruise lite. I donít know whatís going on but my switches to awning lights and below the camper are not working. Another switch that controls lights inside by front door is not working either. Can someone help me
Bri704 is offline   Reply With Quote
Old 12-04-2019, 07:53 PM   #2
rracer5's Avatar
Originally Posted by Bri704 View Post
Hello I have a 2018 Salem cruise lite and my awning lights top and underneath camper also my interior lights don’t work near front door. I don’t know what’s going on I looked for in line fuse but can’t find one. Can anyone help me please
Check in your electrical distribution box for a blown fuse. Or, you could have one of these in line somewhere between battery and switches. The little black button on the end is a reset
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-04-2019, 07:57 PM   #3
Thanks no blow fuse in electrical box. Would that in line fuse be before the converter ? Everything else works but the 3 switches to outside lights and interior lights by door entrance. I looked behind switches and didn’t see any in line fuse
Old 12-04-2019, 08:00 PM   #4
So I should just trace cables from battery and see where they go to find Inline fuse?
Old 12-04-2019, 08:03 PM   #5
rracer5's Avatar
Yes. They're usually not too far from the battery.
2014 Sanibel 3250
Old 12-04-2019, 08:06 PM   #6
Is that in line fuse just for the switches for lights? I wish there was a wiring diagram for this camper
That in line fuse if it was tripped it wouldn’t shut off everything or just certain circuits?
Old 12-04-2019, 08:07 PM   #7
rracer5's Avatar
What model is your cruise lite?
2014 Sanibel 3250
Old 12-04-2019, 08:12 PM   #8
I don’t have model number right now but it’s the one with bunk beds
Old 12-04-2019, 08:28 PM   #9
rracer5's Avatar
I donít have model number right now but itís the one with bunk beds
OK, so I'm assuming a TT. Follow the battery cables from the battery to where they disappear just under the front nose. The negative will most likely be screwed to the frame somewhere nearby. The positive(s) (red, hopefully) could possibly go to one or more of those resettable circuit breakers which may be mounted to the front lower crossbar (frame). If not, and the cables continue through, over or under the frame, you'll just have to trace them out. Good luck.
2014 Sanibel 3250
Old 12-04-2019, 08:33 PM   #10
Thank you for the help
Old 12-04-2019, 08:48 PM   #11
rracer5's Avatar
I have a large 5th wheel so the electrical system is probably a bit more intricate than a TT. Here's what mine looks like. Yours might look smaller, simpler or just be individual breakers. Keep us informed. Believe it or not, there are 4 circuit breakers in there.
2014 Sanibel 3250
Old 12-04-2019, 09:30 PM   #12
Hello I have a 2018 Salem cruise lite and my awning lights top and underneath camper also my interior lights donít work near front door. I donít know whatís going on I looked for in line fuse but canít find one. Can anyone help me please
Do your interior lights have a little button in the center ? Certain LED lights, like the ones in my TT can be either turned on by the wall switch or the button in the center of the light. My awning lights and other accent lighting all seem to come off the converter...if I remember my fuses correctly. You plugged into Shore Power ?
TheWolfPaq82 is offline   Reply With Quote
Old 12-04-2019, 09:50 PM   #13
Carknocker Family
Ida Ratherbe Camping's Avatar
Make sure someone didn't work the lights with the remote. Someone sometime did on mine and couldn't turn them off.
Ida Ratherbe Camping is offline   Reply With Quote
Old 12-05-2019, 07:48 AM   #14
Did anyone ever had their awning pinch their led outside light wires. i notice a little cut and flat part of wire coming from awning track to led outside lights. maybe water got into the cut wire to shut off my switches ?
Old 12-05-2019, 07:53 AM   #15
wiring diagram
hello everyone,
I wanted to see if anyone knows if there is a wiring diagram for 2018 forest river salem cruise lite travel trailer.
Old 12-05-2019, 07:58 AM   #16
hello everyone,
Wiring and plumbing diagrams don't exist for most TT's / Fivers. When manufactured, the wiring seems to be wherever the assembler at that time feels like putting it. Tech showed me a trailer identical to mine and the wiring was significantly different than the way mine was wired.
Old 12-05-2019, 07:59 AM   #17
Head Rambler
I don't think I've ever seen a wiring diagram for any of those units. If you'll post the model of you unit, an owner of the same model may have made one of their own. Even with that, your unit and another identical unit may be wired differently.
What in particular are you looking for?
Gotta go campin!
Old 12-05-2019, 08:08 AM   #18
Thank you guys just wondering it would make things a whole lot easier to troubleshoot electrical issues
Old 12-05-2019, 08:11 AM   #19
Yes it would. But first they need to have a "standard" for how and where the wires are run. Until then....it's a crapshoot trying to trace where everything goes.
Old 12-05-2019, 08:13 AM   #20
bama rambler i was looking to find out why my awning outside lights dont work and part of interior lights either. my switches dont work for those lights. i found a cut wire where my awning retracks go to top led light i think water got in and shorted the light. all 3 switches seem to be connected and i checked electrical box and no blown fuse
awning, diagram, led, light, wiring
