Old 01-19-2015, 10:06 AM   #1
LED Replacement S/T/T and Marker Lights
Hi,
I have a 2015 Primetime Avenger 26BH, and I'm less than impressed with the brightness of the stop/tail/turn lamps and clearance markers. Looking at the design of the fixtures i think that it is a problem with the way they are built more than anything (for example the 912 bulbs are recessed in the fixture as opposed to being laid sideways as in most fixtures, and the backing being black as opposed to a reflective material to help fill the reflective material on the outer lens) and was wondering if anyone has tried replacing the stock incandescent bulbs with LEDs, or adding some sort of reflective material to the back of the housing and if so what the results were. Thanks for your help and I look forward to hearing from you!
RussellK is offline   Reply With Quote
Old 01-19-2015, 10:08 AM   #2
TURBS's Avatar
I replaced mine all with 13 led marker lights.
Old 01-19-2015, 10:09 AM   #3
Fulltime family RVer
Where did you buy the new lights? I was thinking about doing this.
ependydad is online now   Reply With Quote
Old 01-19-2015, 10:12 AM   #4
TURBS's Avatar
I bought them for 5 or 6 a piece I believe.
I can still get that price if you want.
ID:	68622   Click image for larger version
Old 01-19-2015, 10:15 AM   #5
Turbs,
Did they mount in the preexisting holes?
Old 01-19-2015, 10:16 AM   #6
TURBS's Avatar
I bought mine local but these are what I bought.
http://odmrv.com/catalog/index.php?m...roducts_id=979
Old 01-19-2015, 10:17 AM   #7
Thanks, TurDs. I'll check them out and may likely plan for these as a spring job.
Old 01-19-2015, 10:21 AM   #8
TURBS's Avatar
Originally Posted by RussellK View Post
Turbs,
Yes.
They are bright!
Old 01-19-2015, 10:21 AM   #9
TURBS's Avatar
Text sent.
Old 01-19-2015, 10:24 AM   #10
TURBS's Avatar
Also the link I sent shows a one wire with grounding strap, the ones I buy have a hot and ground wire .
led, light, replacement
