09-03-2018, 12:00 PM
Camp-N-Nut
Level up system
Level up system stopped working. The screen lights up but no words appear on the screen. I can only raise and lower the front jacks. The front and right lights are lit on the panel. I disconnected the power then reconnected the power but it didn’t change anything. Any help?
2015 Cedar Creek 34 RLSA
2006 Dodge Laramie Dually Cummins
09-03-2018, 12:14 PM
Will the ones lit up work
09-03-2018, 12:17 PM
Camp-N-Nut
No. Can only raise and lower the front.
09-03-2018, 12:22 PM
Battery level good?
09-03-2018, 12:23 PM
Parking brake on
09-03-2018, 12:26 PM
Originally Posted by camp-n-nut
Level up system stopped working. The screen lights up but no words appear on the screen. I can only raise and lower the front jacks. The front and right lights are lit on the panel. I disconnected the power then reconnected the power but it didn’t change anything. Any help? Attachment 185299Attachment 185300
You might try resetting by pulling fuse and replacing. Fuse is in compartment where pump is. Single inline 15 fuse.
2016 FR Sierra 377FLIK
2016 GMC Sierra 2500HD Diesel
09-03-2018, 01:33 PM
Camp-N-Nut
Battery level is fully charged. I pulled the fuse and it was good but replaced it anyway. I can raise and lower the front landing jacks with the touch pad. It won’t do anything else.
09-03-2018, 01:47 PM
Warranty?
09-03-2018, 02:09 PM
If removing all power to the panel and the controller box does not help, you might have bad components. Call Lippert tech line and they will walk you through some diagnostics and possibly send you parts.
Download the manual for your system from the Lippert website for reset instructions and pics of components.
https://www.lci1.com/level-up
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-03-2018, 02:42 PM
Certified Curmudgeon
Try pulling the plug off the back of the control panel.
For those who don’t know: The towable level up is different than the motorized level up.
Mike Dropped
09-03-2018, 06:08 PM
Do this.
09-03-2018, 06:49 PM
Level Up
I lost partial functionality in mine too. I could extend but not retract all legs. Lippert helped me figure out to switch two wires to allow me to retract (but not extend). A chip on the controller board fried and a new controller fixed it.
After opening up the controller, I could see the fried chip. I think it was related to trying to use the hydraulics during a cold snap (maybe condensation on chip).
I replaced hydraulic fluid with synthetic ATF which seems to put less work on the pump when cold.
09-03-2018, 07:07 PM
Which synthetic did you use? Thanks....
09-03-2018, 07:13 PM
I used Amzoil Synthetic ATF. I had it for another vehicle.
6-7 quarts.
Also added "Anti-Stiction" fluid (1 quart) as per Lippert suggestions.
09-03-2018, 07:44 PM
I used Mobil 1 in my Creek, Coachmen and now in my Sunseeker. Never needed anti stiction additive, never popped after the changeover.
Mike Dropped
09-04-2018, 04:28 PM
Try disconnecting and reconnecting the control wiring harness connector at the LCD panel. This worked for me.
