Old 05-09-2012, 04:34 PM   #1
Exclamation Lexington Cabin battery Not Charging
we can charge the cabin batteries when we plug into 110 volt service and they charge overnite. however, the batteries do not charge off the engine while we are driving down the road. we replaced the fuse on the solenoid, and the result was a very minimal voltage on the volt meter....any suggestions. the readings were taken with the batteries removed, checking the hot lead against the ground.
lexington motorhome 24 ft (2004)
Campinghawkeye is offline   Reply With Quote
Old 05-09-2012, 06:17 PM   #2
Herk7769's Avatar
If the title change does not work I will move it to the motor home section.
I wish I could help you but all I can do is post some manuals that might help you.
Sounds like it could be your isolation relay.
File Type: pdf Battery Control Center Information -1.pdf (1.34 MB, 45 views)
File Type: pdf BiDirectional Isolator Relay Delay.pdf (105.0 KB, 34 views)
