Old 02-12-2014, 11:08 AM   #1
Light bulbs
My wife and I are trying to figure out how to remove the light bulbs that came in our 2014 Forest River 2500 TSF.
They appear as if they push in and out, but they are not coming out easily and we are concerned about breaking them.
We either want to -- have the proper replacement bulbs OR switch them for LCD bulbs.
Can anyone provide any insight?
sfulkrod is offline   Reply With Quote
Old 02-12-2014, 11:25 AM   #2
Brother Les's Avatar
There are basically three types of light bulbs in a camper.
The 110v screw in and screw out like a house light bulb.
The 'tail light' light bulb that have a 'nub' on each side where it is pushed in. Push in and twist to the right. It will settle into a little slot as a spring pushes on it from the back side. To remove, push in and twist 1/4 to the left and pull straight out.
The push pin type will push right in and you should be able to pull it straight out.
Brother Les
Old 02-12-2014, 12:29 PM   #3
Inside lights
I am referencing the inside lights and how to get them out.
What bulb size are they for replacement?
What LED bulb should I replace them with?
Steve
Old 02-12-2014, 12:34 PM   #4
TURBS's Avatar
You'll have to look at the bulb to get the correct number as they can and will use different bulbs for different fixtures.
912 and 921 are common.
TURBS
Goshen is my playground.
The last man standing also has a sharpie
light
