Old 07-14-2015, 07:06 AM   #1
FR3 Grampy
Light doesn't work
The light over the bed doesn't work. When I took it apart and checked to see if I had 12V coming to it lit up. I'm thinking maybe I have a loose ground. The problem I have is that the light is on the pop out and I don't know where the wiring is going. Can anyone help me locate the wiring to this light?
Scottmarm is offline   Reply With Quote
Old 07-14-2015, 07:32 AM   #2
Flybob's Avatar
The wiring for my slide is under the slide and has a bow shaped cable management protector that allows the slide to move in and out without damaging the cable.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-14-2015, 09:00 AM   #3
It could also just be a bad bulb and the filiment is bouncing making contact.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
light
