Old 05-10-2014, 04:52 PM   #1
Light next to fuse not come on???
Why in the power sector when I take out a fuse that the light next to the fuse still not come on? Some do, however some don't??? Any ideas??
26TBSS wildwood
tbeefitz is offline   Reply With Quote
Old 05-10-2014, 05:14 PM   #2
Fuse failure indicator light is what I am referring too. It is adjacent to the fuse.
Old 05-10-2014, 05:27 PM   #3
Explorer
Do you have LED lights in the circuit where the fuse is pulled from?
I chaseda similar issue for a couple days then I called the manufacture(Progressive Industries). To make the LED blown fuse indicator light they supply one tenth the voltage to the circuit side of the fuse. This should light the LED indicator when fuse is blown but if there are LED lights in the same circuit then those LED will draw that small amount of voltage.
http://www.forestriverforums.com/forums/f218/dim-leds-phenomena-55706.html
This was my issue,
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 05-10-2014, 05:53 PM   #4
you have to be pulling power from said fuse, find one for the main lights and turn them on, and pull the fuse, and the LED will light, turn the switch off and the LED will go out and come back on with switch. I found out the hard way myself.
blugrasbaseman is offline   Reply With Quote
Old 05-10-2014, 06:08 PM   #5
Explorer
I said voltage but I should have said amperage
John
fuse, light
