Old 12-05-2015, 04:22 PM   #1
Light not working
This light over our sink isn't working. Never has. Would rather not pull back to dealer for this. Are the two tabs to pop it open? Anything serviceable here to look at ourselves? Just pry open with a screw driver?
episodic is offline   Reply With Quote
Old 12-05-2015, 05:02 PM   #2
fonzie's Avatar
In my unit, I have a switch at the entrance that needs to be on and also the switch on the fixture to be on to work.....see thread for lens removal.
Interior oval light lens removal
Fonzie
Old 12-05-2015, 05:16 PM   #3
Head Rambler
You might want to take it down if replacing the bulb doesn't fix it and look at the wiring. I've seen more than one that had a wire loose going to the lamp.
Gotta go campin!
Old 12-05-2015, 05:19 PM   #4
Mr. Dan's Avatar
Fonzie's suggestion should be studied. I've had this problem before with either the wall switch or the switch on the lamp being OFF. Both must be ON. I'd investigate this possibility before I disassembled anything.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
light
