Old 07-23-2016, 01:52 PM   #1
Light Switch/Lights not Working
Help! We have a 2007 Cherokee 28bh fifth wheel and cannot get two lights to work up in the master bedroom. There is a dual light switch outside the bathroom door one that works the bathroom light (which works fine) and the other we assume controls the two lights that don't work above the sink and shower. All fuses work, light bulbs have been tested...any further suggestions?!? Thanks!
Bauerash05 is offline   Reply With Quote
Old 07-23-2016, 03:30 PM   #2
Does the bathroom light need to be on in order for the other switch to work? Next step would be to remove the lights and check for loose wires or wire nuts. Step 3 would be to remove the switch and see if it functions properly with a ohm meter. Sometimes a light might be turned off at the light itself thus making the wall switch non-functional.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 07-23-2016, 03:47 PM   #3
Head Rambler
Bob got my suggestion of checking for a switch on the light itself.
The next thing is as he said check for power not only at the lights but at the switch too.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
electrical, light, switch
