Old 08-12-2013, 01:43 PM   #1
Light - voltage problem?
Ceiling light that is controlled by wall switch or switch on fixture quit working, checked bulbs were ok. Figured either problem in switch or fixture. Happened to be replacing all the bulbs with LEDs. When put LEDs in fixture they would come one but very, very dim.
So apparently not enough power was going to light to run regular bulbs and barely enough to get LEDs to light. All other lights work fine.
Any ideas of what may be causing the low voltage to this fixture?
David & Sherry
2012 Wildwood 28BHXL
2013 GMC Sierra SLE
wvcampincpl is offline   Reply With Quote
Old 08-12-2013, 08:50 PM   #2
If the type of socket those bulbs are in allows them to be inserted "the other way", make sure you try that with the LEDs. They may be polarity sensitive.
Old 08-20-2013, 09:57 PM   #3
Bad ground creating too much resistance and thus not enough voltage to the light?
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 08-21-2013, 10:52 AM   #4
Check the 12V fuses. There is generally a RED LED indicator light when the fuse is blown. That RED LED indicator light may be supplying enough current to light up the LED bulb in the fixture dimmly, but not enough to illuminate a regular bulb.
The RED 12V indicators on the fuse panel are usually in parallel with the fuse. If the fuse is good, you will get the full 12V and can supply current upto the rating of the fuse. If the fuse is blown, or removed, the circuit will actually still be supplied 12V but only the very small amount going through the RED indicator LED on the fuse panel. This may be around 20mA or so. That's enough to light the LED on the fuse panel, but not enough to fully turn on an LED fixture bulb.
If the fuse blows again when you replace it, you may have a short circuit somewhere.
SCOC is offline   Reply With Quote
light, voltage
