Old 02-26-2015, 12:20 PM   #21
Crockett's Avatar
the OP stated voltages ..i.e.meter. i dont care about the amp draw of the 80 amp. fuses blow, automatic circuit breakers trip and reset even if imbeddedin a power converter...
Crockett is offline   Reply With Quote
Old 02-26-2015, 12:27 PM   #22
TURBS's Avatar
YOU suggested a convertor that the op would have to run a new circuit to even use.
And it could possibly use up another precious 5 amps worth of incoming power.
I've been down this road many times and not once has it been anything other than a bad battery or a convertor when the lights dim and then get brite.
TURBS
Old 02-26-2015, 12:46 PM   #23
Crockett's Avatar
i stated that I would not consider an 80 unless I had more than 2 batteries. It was not suggested. my apologies if that "perturbed" you...
Old 02-26-2015, 12:50 PM   #24
Crockett's Avatar
breakers are often mounted between converters and batteries. these can be damaged and need replacement when the offensive battery is replaced...everything is speculation here since no one is present to troubleshoot for themselves
Old 02-26-2015, 12:53 PM   #25
TURBS's Avatar
Lol you didn't perturb me yet . [emoji15]
Only oc does that.
TURBS
Old 02-27-2015, 08:58 AM   #26
Herk7769's Avatar
So I did not see a post about checking your ground wires.
There are two. One at the converter (to the frame - and may be hard to get to) and one at the battery negative cable.
If the converter ground is loose/corroded it will act just like a failing converter since the converter will loose continuity with the battery.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
light
