Old 12-19-2011, 04:20 PM   #1
Unhappy lights won't work
I have a Sierra 5th wheel - the light over the chesterfield and the 2 over the table have stopped working. Have changed bulbs and checked fuses. Apparently there is a 'switch' somewhere but can't find it - all suggestions gratefully accepted!
ABSunshine is offline   Reply With Quote
Old 12-19-2011, 06:26 PM   #2
JAYCO Representative
Wildcat Chris's Avatar
All of those lights are in the slide room and are usually on a single switch. Perhaps a current Sierra owner can assist you -- what year and floor plan do you have?
Oh, and for those who were wondering, a chesterfield is a sofa in Canada...
Chesterfield Sofa - Wikipedia, the free encyclopedia
Wildcat Chris is offline   Reply With Quote
Old 12-19-2011, 08:16 PM   #3
Thx WC re 'sofa' my other option was 'couch' so hoped for the best! Since I'm Canadian, not sure of the USA lingo sometimes.
I think my rig is a 2008 the area not lighting is in the slide. However, the light that is attached to the wall does work. Hopefully someone will be able to tell me were they hide this 'switch' you mention as sure would like it to be that easy.
Old 12-19-2011, 11:59 PM   #4
Just a member
kandl's Avatar
Holy hockey-socks, haven't heard that term used in 20-odd years - and I'm an over-the-hill Canuck! Maybe cuz we spend too much time in the redneck part of Canada?
If you're shopping for a sofa/couch at any of the major retailers in Canada, the sales rep will likely be giving you that deer in the headlights look if your ask to look at their chesterfields. The Wiki article says it's a Canadian term but my vote goes to it being a British term that got adopted along that historical pathway.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
kandl is offline   Reply With Quote
Old 12-20-2011, 12:04 PM   #5
my light issue
loved the banter but it still hasn't given me the solution to my lighting problem
Old 12-20-2011, 12:47 PM   #6
Dave_Monica's Avatar
The 12V power feed for these overhead lights is probably under the slide. Check and see if any of the wires have been damaged when moving the slide in or out.
Dave
Old 12-20-2011, 12:49 PM   #7
caper's Avatar
Check the wiring under your slide out. I had a bad connection with a wire connection that was in a wrapped in a plastic wire cover. It was a butt connection that the wire was not pushed in far enough before it was clamped. It took almost two years before it lost its connection. Good luck on finding the problem.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-21-2011, 11:50 PM   #8
rracer5's Avatar
I was thinking chesterfield was a very popular style of furniture (chest-of-drawers) at one time so, I thought you were talking about the light over the dresser in the bedroom!
Anyway.....since both lights are in the slide, I would suspect a wiring issue under the slide. Open the slide, locate the 12v wiring and how it's routed. See if it appears to be pulled too tight when the slide is fully open. Then if you can safely, have someone close the slide while you watch the wiring to see if it kinks or gets "pinched" anywhere when the slide closes. If so, then that will give you a starting point to look for a break.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-22-2011, 04:29 PM   #9
thx- on the top of my list right after New Years - right now it's just time to enjoy the season!
Old 12-23-2011, 12:33 PM   #10
Water closet anyone?!!!!!!!
MARTIMER is offline   Reply With Quote
Old 01-05-2012, 10:02 AM   #11
jim44646's Avatar
Don't forget to flush your water closet!!!!
jim44646 is offline   Reply With Quote
