Old 11-06-2012, 02:57 PM   #1
Lithionics Lithium Ion batteries
Sorry if this has already been discussed...
Anybody heard of these? How good they are? Cost? I saw them on an automotive tech show called "Truck U" where they were replacing the battery in their Dodge Ram with one of these. I looked on their site and saw they have batteries for the RV and marine sector as well. They claim "increased dry camping time" when compared to traditional batteries. My main concern is cost, followed by capabilities/how long it holds a charge, then how long it takes to recharge. Thoughts?
Lithionics RV Li3 Batteries
700hauler is offline   Reply With Quote
Old 11-06-2012, 03:13 PM   #2
Herk7769's Avatar
Man those batteries are HUGE and weigh a ton.
Not sure my Ultra-lite frame can support them.
You can buy a LOT more amp hours for much less in a lead acid deep cycle battery.
If money, size, and weight is no object, a couple of those would be awesome.
HAM CALLSIGN - KC3FFW
Old 11-06-2012, 04:51 PM   #3
Triguy's Avatar
I like the idea. I think its on the bleeding edge of batteries and not much real-user experience out there AFAIK.
I think I saw this company mentioned on another site last year when they first came out with the RV battery but I can't find the link. From what I recall, they can be discharged deeper than 50% without problems and discharged more often and recharge faster. Also, there's no maintenance with a lithium battery.
I believe they are lighter than an equivalent bank of 6-volt batteries for the same number of useable amp-hours.
That's the good stuff IIRC. The bad was the price, which I don't see anywhere on the website. I understand that they are mucho $$$. Also, where can you buy them, how long is the warranty and how do you get service if there is a problem?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 11-06-2012, 05:33 PM   #4
Phat Phrog Stunt Crew
awwall's Avatar
We all need a few of these...reasonably priced!!!
12V400A-8D
The WEIGHT: 125 Pounds
The POWER: 12.8 Volts, 400 Lithium Amp Hours
Emergency Cranking Amperage: 2000 A
Charge Voltage: 14.4 to 14.4 V (use the Gel setting on your inverter-converter)
Recommended Charge Amperage: 40-60 A
Max Charge Amperage: 600 A
Internal Impedance: <8Milliohms
Life: 3000 Cycles Minimum at 80% Depth of Discharge
2000 Cycles Minimum at 95% Depth of Discharge
The PRICE Leader: Full Factory Automation, Made in the U.S.A.
The SAFETY Leader: Approved to U.N. International D.O.T. 38.3 for Lithium
Size (L/W/H) in Inches 23x13x11.4
Includes Pushbutton or Wireless Remote NeverDieģ, 3 Year Warranty
Download Brochure
$5,787.55
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 11-06-2012, 05:50 PM   #5
Herk7769's Avatar
2 feet long and a foot square on the end?
Have to admit 400 AH is pretty cool though.
Old 11-06-2012, 06:48 PM   #6
I'm surprised that you don't need a special charger for these battery's. I was told that lithium battery's needed to be charged in a very specific way or they can get damaged. I wonder if they have some sort of charge controller built in. I know that the lithium ion battery for my drill just stops when it has been discharged to a preset voltage. I know that if you discharge them till there dead they will be permanently damaged, this is why they have the cutoff.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 11-06-2012, 06:54 PM   #7
Wow. $5800! I could by half a dozen Trojans plus an onboard generator for that kind of money.
crasher is offline   Reply With Quote
Old 11-07-2012, 02:38 PM   #8
are they seriously that expensive? Thats crazy!
On the TV show they installed one in the Dodge Ram they were working on. It was the same size as the old lead/acid and weighed only 11 pounds. They said everything about it was better than the lead/acid battery.
I wouldn't imagine the one(s) we would need/use for our TTs would be what awwall posted above. They are probably still super expensive but I don't see them being $5K. Probably more along the lines of $900 a piece.
I look at these like LED lighting technology used to be (kind of still is for some applications) . Super expensive right now but eventually the price will come down to a reasonable range where people feel like its worth it for the benefits.
Old 11-07-2012, 03:29 PM   #9
Herk7769's Avatar
Lithium Ion Battery for Camping with AC and DC Power on eBay!
Crazy indeed
Old 11-07-2012, 04:24 PM   #10
awwall's Avatar
I did not make up this $5800 price tag. I got it from one of their distributors.
Large Scale Deep Cycle Batteries
FROG Member
battery
