Old 12-08-2014, 11:14 AM   #11
You will need a solar controller to charge the Lithium batteries. According to the spec sheet on the battery you need 14.4 to 14.6V for charging.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 12-08-2014, 01:05 PM   #12
WestCoastRV'er's Avatar
You are correct. This is the one I was looking.
12V 60A Lithium Ion Solar Charge Controller - C60 - Xantrex - Lithium Ion Solar Energy Storage Batteries | Smart Battery - Products
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 12-08-2014, 02:19 PM   #13
The main points there are that you need a special "lithium" charger is a bunch of hooey. A lot of folks will get sucked into forking over hard earned cash to replace a perfectly capable "smart/programmable" charger.
The "standard" charger they are referring to are the lower end RV converter/chargers found in almost ALL RV's. (which are highly inadequate for most battery systems currently in use.. ie., flooded deep cycle wet cells)
The charger you referenced is no different. It's just a plain ol "standard" charger with a higher "factory adjusted" output. It is non programmable. You would be better served to buy a true "smart" charger. Programmable, heat adjusted, and full sensor capability. That would be true with your trojans, AGM's OR LFP's.
They are trying to sell ice to Eskimos.
The "catch" they are trying to scare you with is that all LFP cells charge and discharge at different rates. What they only put in small print is that the cell regulation takes place in the individual cell circuitry.. not within the charger. They DO have different charge requirements to stay happy.. but that's just as true with your wet cells and AGM's.
I understand you are trying to look further down the road, but one other factor you might consider is that you really don't want to be slowly adding cells... mixing old and new cells over a period of years.
It's just my own personal opinion.. but if you have a little extra money right now, you would be better served upgrading the "backbone" (charger, solar controller, battery meter) and sticking with the AGM's. Maybe go with 4-6v'rs and give yourself 220ah's on tap (440ah @ 50% discharge).
In 5 years.. once the LFP's are more reasonable in price... and you've gotten your dollars worth out of your AGM's.. THEN make the jump to LFP.
I know there are folks that are able to take advantage of LFP's now.. but typically those folks are running high voltage 24v or 48v system powerhouses. Probably somewhere in the 1% range of typical RV solar setup's... and there is still not much debate over the fact that the $ to Ah is highly unbalanced. Some of those folks are heavy boondockers that NEED that kind of power storage to run their self levers and hydraulics that might over tax a small 12v low power system.
rana is offline   Reply With Quote
Old 12-08-2014, 02:24 PM   #14
I just remembered a good link that has some really great information is simple to understand language with regard to solar and electrical systems. It might be helpful when re-vamping your electrical setup.
RV Electrical
This guy knows his stuff. More so than 90% of solar installers I have ever run across.
Old 12-08-2014, 02:50 PM   #15
thanks for the detailed feedback.
Do you have a suggestion for a smart charger?
Are AGM batteries safe to store inside the RV?
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 12-08-2014, 03:45 PM   #16
AGM's are perfectly safe inside your RV. They can even be installed on their sides or upside down
Chargers.. that's more difficult to answer. So much depends on your overall setup and needs. Ie, are you happy with a smart charger with preprogrammed charge profiles? Do you require temperature adjustment? Do you want it to have pass through power capabilities from shore power? Is your solar controller "smart" too?
KWIM
Old 12-08-2014, 04:27 PM   #17
Caveat: I do not normally pay much attention to stand alone battery chargers.
Just looking around briefly.. there seems to be some good things being said about the IOTA IQ4
and
Zantrex Truecharge2
The Zantrex has the option for a custom setting... which is ideal, but in the owners manual it says:
This setting should only be used
if a custom algorithm has been
programmed by Xantrex or a designated OEM.
battery
