Old 05-24-2012, 10:39 AM   #1
location of fuse for slideout???
I think I blew my fuse on slideout using battery power. Where would I find the fuse for the slidout on 12 roo 23ss. Nothing blown in the box so I thought I had heard someone mention it is under tt before. Thanks
ahanebrink is offline   Reply With Quote
Old 05-24-2012, 10:40 AM   #2
shawnj72's Avatar
Mine has a breaker under TT just behng the toung..
2006 Cherokee Lite 28A
2000 GMC Yukon XL
1 Wife 2 Sons 3 Daughters
2012 Days Camping 17 Practiced Camping in the yard 5/5/2012
shawnj72 is offline   Reply With Quote
Old 05-24-2012, 10:56 AM   #3
TURBS's Avatar
near or close to ur battery may be a resettable curcuit breaker, or an inline fuse .
Old 05-24-2012, 11:02 AM   #4
Could you explain to me a reseting breaker and how and where would I go about doing this. I will take a look around under trailer and see if I can find it, I was hoping to not have to crawl all around so thanks for help
Old 05-24-2012, 11:07 AM   #5
shawnj72's Avatar
There is a suare box mounted to the frame. inside there was a breaker like in your main panel. I just had to flip it down then back up. That was in my Cherokee. Sometime doing a trace from the source and follow the leads. Your model should have A Green 30 amp fuse from the battery to the slide
"Besides the breakers and fuses inside, did you also check the fuse under the camper inline from the trailer tongue? Sometimes people miss this one.
Mine is a 30 amp (green) ATC type fuse and can be found on the slide side about 2 feet from the front of the camper." From a previous post
2000 GMC Yukon XL
Old 05-24-2012, 11:20 AM   #6
Bearcat55's Avatar
I don't have a Roo, but mine is located under the fridge behind a panel that has to be removed. It is a 20 amp inline fuse.
2012 Salem 30KQBSS
2010 F150 S-Crew 4x4 5.4L
Bearcat55 is offline   Reply With Quote
Old 05-24-2012, 11:24 AM   #7
ddemme's Avatar
I have a 23SS. Its under the camper just behind the tongue on the street side.
Drew & Kendra
Lucky & Bentley the camping dogs
2011 Ford F-150 SuperCrew EcoBoost w/tow pkg.
2012 Rockwood Roo 23SS
ddemme is offline   Reply With Quote
