Old 04-23-2015, 03:47 PM   #11
rattleNsmoke's Avatar
12v timer - Newegg.com
How about one of these??
rattleNsmoke is offline   Reply With Quote
Old 04-23-2015, 04:18 PM   #12
Witch Doctor's Avatar
That's a good site I just checked it out and bookmarked it THANKS....
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 04-26-2015, 10:02 AM   #13
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by gljurczyk View Post
IF that is a wind up switch, you can use it for 12v. The switch doesn't know if your passing 12v or 110v,
You are 100% correct. I'd use that rotary switch.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 04-26-2015, 10:10 AM   #14
Still nothing from OP as to what he wants to control. A simple 110v timer switch from Lowes/HD might be just the answer.
Old 04-26-2015, 10:25 AM   #15
AKA: 'tiredTeacher
awellis3's Avatar
OC, OP said:
Originally Posted by Bocephus View Post
I am looking for a 12 volt switch that is also a timer (manually turn on, then time out and open the circuit after 1-60 minutes).
Wright and Penny
Richmond, Va.
Old 04-26-2015, 10:47 AM   #16
Originally Posted by awellis3 View Post
OC, OP said:
Still doesn't tell us what he wants to control. i.e. lights, fan, etc.
Old 04-26-2015, 11:01 AM   #17
I asked him the same question at post#6, all he said that specks said it pulled 1.2 amps DC can't be much but lights or something. Oh he did say he has a $50.00 budget....He said he wanted it simple like the wind up he shown with a 0 to 60 min. timer only. Maybe he figured it out already and like so many others never let folks know. And we are like cattle just keep answering them with idea's....
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-01-2015, 08:22 PM   #18
i am looking for a 12 volt switch that is also a timer (manually turn on, then time out and open the circuit after 1-60 minutes). something similar to what you'd find in a house for an exhaust fan. i have found hundreds of them rated for AC applications. i cannot seem to find anything BASIC for dc applications. i dont want/need a fancy, programmable unit that consumes power to keep its memory.....i just want simple. my budget is $50
i know these are alot less than $50, but something like this for DC applications would be perfect. the smaller the better.
Not quite $50.00 but, this will do what you're asking
(have a programmable timer) & much more.....not all info. is on the site but a ph. call will get all.....I can't take credit for this find; "Old Coot" here on our forums put me on to this product.....can't thank him enough!.....I am using two of these systems in my TT.....one of them as "3/way"......these RX's (switchs) can be "Taught" to listen to something like 30 different "TX's" (wall mounted push/buttons).....you can control a circuit from 30 different locations!.....FWIW
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 05-02-2015, 03:39 PM   #19
Originally Posted by Jim in Halifax View Post
Majority of cases you can use an AC switch for DC but not the reverse.....You have to read the specs stamped on the unit.........J
I have used AC switches for DC applications with no probs!!!!!!!!!!!! J
Jim in Halifax is offline   Reply With Quote
Old 05-16-2015, 03:22 AM   #20
well, the common household timer switch works like a charm guys. thanks for the help. i am using it for a fuel transfer pump going from the auxiliary tank in my bed of my pickup to the main tank. i wanted it on a timer so i wouldnt forget the pump on.
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
manual
