Old 09-02-2015, 06:24 PM   #1
Loss 12v
Connected to shore power 110v refrigerator dont work on 110v other plugs ok no 12v anywhere gfi switch ok main cutoff 12v ok. I'm lost
Pierre Allard is offline   Reply With Quote
Old 09-03-2015, 08:46 AM   #2
Head Rambler
The fridge requires 12 volts to the control board even to operate on 120 volts. If you have no 12 volts then the fridge won't work.
Have you checked all the fuses in the converter/power panel?
Have you checked the Short-Stop circuit breaker near the battery?
It would help if you told us what unit you have and what converter you have.
Gotta go campin!
Old 09-03-2015, 10:05 AM   #3
Finally checked inside panel, 2 40a and 2 25a where busted.
Now wondering why this happen. Put in new one's and everything works great for now else the battery is down and recharging now.
Old 09-03-2015, 10:09 AM   #4
Power surge ? Lightning Strike ? Gremlins ?
wanderingbob is offline   Reply With Quote
Old 09-03-2015, 10:14 AM   #5
TURBS's Avatar
Did you recently install or hook up the battery backwards?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 09-03-2015, 01:25 PM   #6
TURBS
2011 32bhok Sabre
No work on it was done. It was hook to power line 110V for about 4 days in my driveway than when I went inside I find out there was no more 12v. Was no storm here, no lightning. So I really dont know why this happened while being park in driveway and nothing on power else the refrigerator.
Old 09-03-2015, 01:35 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Pierre, this can happen when you plug the cable in with the breaker on on the pedestal (in your scenario your home), it is not very common but ....
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-03-2015, 03:02 PM   #8
It would have happen 2 days after I plug to home ??...makes no sense...I was told at store where I got the 40a fuse that it was a record week of selling 40a at their store...so I imagine it could have been the weather flash lightning or else in our area... Sherbrooke, Québec, Canada
Old 09-03-2015, 03:29 PM   #9
You're right, that doesn't make sense.
