Old 06-27-2016, 08:52 PM   #1
Low voltage
I just replaced a CO/LP sensor and am getting a low voltage error message. Resetting the sensor results in the same error. I am plugged into the same circuit at my home I have used for two years without an issue.
How and where can I check the voltage in my unit? Forest River Mini-Lite 2015 2109S
Thanks. I'm still learning.
plmoss is offline   Reply With Quote
Old 06-28-2016, 11:41 AM   #2
Head Rambler
If you know how to use a multimeter you can check the voltage at the panel as well as the detector itself.
Gotta go campin!
voltage
